| Shivers |
Sep 9 2024, 08:42 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,335 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I moved this from the Paddock, thought I put it here. Because the port is almost straight, with little long side short side turns, with what there is , do you find it necessary to slow the flow down on the “short side” to get good flow out of the valve. I was reading about something mepstein posted a picture of. Small divots, like a golf ball. So I’m going to do that on the long side, just wondering if there is any reason not to also do it on the short side. Thanks guy’s smile.gif
| Superhawk996 |
Sep 9 2024, 11:07 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
FWIW the intake port isn’t the bottleneck to flow, it’s the exhaust that has to practically make a 90 degree turn in a very short distance.
| Shivers |
Sep 9 2024, 12:21 PM
FWIW the intake port isn’t the bottleneck to flow, it’s the exhaust that has to practically make a 90 degree turn in a very short distance. Thanks, yes it is, open it up and polish it is pretty much my answer there hoping to get some tips if there are any. It is really short and coming out of the valve so none of this pesky stuff about one side of the ports airflow can blow its turn and cut off the other side of the of the ports airflow messing up getting in the valve effectively. Thanks for the pictures, so far not seeing any speed bumps to slow air down. Seeing a little port shaping, seen that before on a type 4, I’ll keep that in mind, I run carbs so I can match the aluminum intakes. |
| Superhawk996 |
Sep 9 2024, 12:52 PM
Thanks for the pictures, so far not seeing any speed bumps to slow air down. I think you might be misunderstanding the dimples. Or maybe it’s just what you mean by slow down the airflow. They don’t slow down the airflow. They reduce drag by creating a turbulent boundary layer. They help keep airflow attached to the surface as it ducks behind a curving surface. https://www.livescience.com/32446-why-do-go...ve-dimples.html |
| Shivers |
Sep 9 2024, 01:28 PM
Thanks for the pictures, so far not seeing any speed bumps to slow air down. I think you might be misunderstanding the dimples. Or maybe it’s just what you mean by slow down the airflow. They don’t slow down the airflow. They reduce drag by creating a turbulent boundary layer. They help keep airflow attached to the surface as it ducks behind a curving surface. https://www.livescience.com/32446-why-do-go...ve-dimples.html Thank you, yes I do understand the theory. I’m looking to see if anyone had to put bumps in to cause turbulence which will slow the air down. It does not look like, on the ports I’ve seen so far in these pictures that this is happening. I’ve read a couple articles on it, and what they are saying is basically what you said. In the little divots it creates a little storm. That pressure created holds the airflow off the metal like a lubricant. It is going to take forever to do all four ports but from what I have read, it will be worth it to get that extra velocity. |
Shivers Porting a type 4 head Sep 9 2024, 08:42 AM
burton73 @Shivers
Just so you can see the HAM RAT head on ... Sep 9 2024, 11:29 AM
rfinegan Here is a pic 2.0 Porsche heads for my intake. Not... Sep 9 2024, 11:43 AM
rfinegan @burton73 can you post a pick or 2 of the chamber... Sep 9 2024, 12:14 PM
burton73
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 9 2024, 06:05 PM
914werke Bob do you have pics of the exhaust? Sep 9 2024, 12:17 PM
Superhawk996 Take a look at this thread and exhaust port cutawa... Sep 9 2024, 12:36 PM
Shivers
Take a look at this thread and exhaust port cutaw... Sep 9 2024, 01:45 PM
Shivers Why golf balls are dimpled. ... Sep 9 2024, 03:57 PM
Shivers Calabria says the optimal surface coverage with di... Sep 9 2024, 04:09 PM
Shivers @burton73
Thanks Bob :) Sep 10 2024, 08:23 AM
Shivers It tells me that someone that knows a heck of a lo... Sep 10 2024, 01:57 PM
infraredcalvin If I’m understanding correctly, there is a short... Sep 10 2024, 07:37 PM
Shivers
If I’m understanding correctly, there is a shor... Sep 10 2024, 09:21 PM
live free & drive This video explains more clearly about how dimples... Sep 10 2024, 09:59 PM
Shivers
This video explains more clearly about how dimple... Sep 10 2024, 10:06 PM
Shivers
This video explains more clearly about how dimple... Sep 11 2024, 08:20 AM
technicalninja
This video explains more clearly about how dimple... Sep 11 2024, 08:00 AM
technicalninja I'd always wondered IF the dimples would help ... Sep 11 2024, 09:44 AM
Shivers
I'd always wondered IF the dimples would help... Sep 11 2024, 12:22 PM
nivekdodge take blowgun, place golf ball on top , in the air... Sep 11 2024, 11:47 AM
burton73
take blowgun, place golf ball on top , in the air... Sep 11 2024, 12:35 PM
Shivers
[quote name='nivekdodge' post='3166959' date='Sep... Sep 11 2024, 01:28 PM
Shivers I was thinking about what that guy was saying abou... Sep 12 2024, 11:35 AM
Superhawk996
Hmmmm
Better dimple those velocity stacks :poke... Sep 12 2024, 04:09 PM
Shivers
Hmmmm
Better dimple those velocity stacks :pok... Sep 12 2024, 04:30 PM
rfinegan @burton73
Thanks for the pics of the 2.0 chambers... Sep 12 2024, 04:22 PM
Superhawk996 Caveat - these are the 2.0L AA Chinese head casti... Sep 13 2024, 05:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:35 AM |
