| friethmiller |
Sep 10 2024, 11:04 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,207 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
Help! My red '74 has a headlight issue. The plastic push rod that came from 914rubber has come off the post (i put back on for the photo). The other day it slipped off and my light closed while driving at night. You can see it has a little "bend" to it. I thought there might be a locking grove on the post where I could prevent this from happening. Didn't see one. There's a grove and c-clip on the motor side, why not here? How'd it work from the factory? @Mikey914 , what am I missing here? Parts? Thanks in advance.
| Mikey914 |
Sep 10 2024, 01:35 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Everything should line up. That way its pushing perpendicular. Also if the bucket got jambed, the nylon is supposed to deform to take the load off the motor. You may be aboe to straighten it, if that is oart of the issue.
The nylon washers are also intendend to help line it up. Do notice the arm has a washer soacer in the part, so with the washer on the same side that coukd be part of the issue too. |
| friethmiller |
Sep 10 2024, 02:26 PM
Everything should line up. That way its pushing perpendicular. Also if the bucket got jambed, the nylon is supposed to deform to take the load off the motor. You may be aboe to straighten it, if that is oart of the issue. The nylon washers are also intendend to help line it up. Do notice the arm has a washer soacer in the part, so with the washer on the same side that coukd be part of the issue too. Like me... you've got some typing skills! (IMG:style_emoticons/default/lol-2.gif) Understand. Thanks for assistance! |
friethmiller Headlight Push Rod Sep 10 2024, 11:04 AM
Ishley Ian Karr's video here should help. Check the ... Sep 10 2024, 11:39 AM
friethmiller Thanks! It looks like the plastic washer does... Sep 10 2024, 01:01 PM
Mikey914 typing fast on a phone with sausage fingers Sep 11 2024, 10:31 AM
dr914@autoatlanta.com you are missing a clip
[b]Help! My red ... Sep 11 2024, 11:44 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:43 PM |
