| SKL1 |
Sep 11 2024, 01:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,778 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest
In the process of repainting my '71 and adding the bulkhead 6 engine mount. While the car is all apart I remember seeing someone do an access panel in the bulkhead for "emergency" engine access.
Does anyone have pictures of such a modification? TIA. |
| SirAndy |
Sep 13 2024, 12:38 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Just remember, it's called a FIRE-Wall for a reason.
Don't use any flammable materials, not even for the sealing/gasket. It can make all the difference between having 30 seconds to get out of the car and burning alive. (IMG:style_emoticons/default/unsure.gif) |
| 930cabman |
Sep 13 2024, 01:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,572 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Just remember, it's called a FIRE-Wall for a reason. Don't use any flammable materials, not even for the sealing/gasket. It can make all the difference between having 30 seconds to get out of the car and burning alive. (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/agree.gif) Make it tight fitting like the post #3, you will be fine. It's easy to change the belt, check timing, not so good for removing the alternator |
SKL1 Bulkhead engine acess panel? Sep 11 2024, 01:59 PM
Montreal914 Recently been looking at this. Here is a thread wi... Sep 11 2024, 02:32 PM
Garland @[url=http://www.914world.com/bbs2/index.php?showu... Sep 11 2024, 02:36 PM
Steve With the right tools, you can easily change the fa... Sep 11 2024, 04:39 PM
Cairo94507 On my 2nd 6, back in the mid-80's, we did an a... Sep 13 2024, 06:03 AM
930cabman
On my 2nd 6, back in the mid-80's, we did an ... Sep 13 2024, 12:00 PM
73-914
Just remember, it's called a FIRE-Wall for a ... Sep 13 2024, 03:42 PM
worn
Just remember, it's called a FIRE-Wall for a... Sep 13 2024, 06:21 PM
ClayPerrine
Just remember, it's called a FIRE-Wall for a... Sep 14 2024, 10:13 AM
914werke If someone is interested I have a cut panel sectio... Sep 13 2024, 01:34 PM
Cairo94507 My current 6 (Irish Green) is my 3rd 6 and 4th 914... Sep 14 2024, 06:54 AM
mepstein Well sure, you are cutting a hole but then you are... Sep 14 2024, 10:48 AM
ClayPerrine
Well sure, you are cutting a hole but then you ar... Sep 14 2024, 07:15 PM
worn
Well sure, you are cutting a hole but then you a... Sep 14 2024, 09:28 PM
930cabman Having the steel firewall is great, but having the... Sep 15 2024, 06:20 AM
mlindner I installed an acèss panel, love it, sealed. Grea... Sep 15 2024, 07:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:38 PM |
