> Brembo cable actuated parking brake.., hmmm...wonder what these cost?? :)
Mueller
post Jan 31 2005, 09:56 PM
914 Freak!
Doing some "surf'n" and came across these being installed on an Audi A4
I never knew that they made a parking brake caliper...
andys
post Feb 1 2005, 01:21 PM
QUOTE (Mueller @ Feb 1 2005, 10:22 AM)
[QUOTE=BigD9146gt,Feb 1 2005, 10:15 AM]
The problem with the Wilwood Spot calipers is that they are only for a .38" width rotor, so if you want to use it outboard on vented rotors, you'll have to open it up and make custom spacers....adding to the cost of the conversion.....
Spacers pretty easy to do on the Wilwood spot. Also, Rennegade Hybrids was making a spot caliper to fit a 914....I said WAS, as I couldn't find it anywhere on their site. There were some pic's of it floating around sometime back. Perhaps contact RH?
Andy
Mueller   Brembo cable actuated parking brake..   Jan 31 2005, 09:56 PM
Mueller   one more shot.....   Jan 31 2005, 09:56 PM
iiibdsiil   Someone please have pricing and it better be cheap...   Jan 31 2005, 10:25 PM
cdmcse   I am seriously considering using these.... Wilwoo...   Jan 31 2005, 10:36 PM
scott thacher   here is a simply way to make a parking brake. buy ...   Jan 31 2005, 11:06 PM
bondo     Jan 31 2005, 11:29 PM
ArtechnikA     Feb 1 2005, 09:52 AM
bondo   Our 87 Subaru GL-10 has it's parking brake in ...   Feb 1 2005, 10:53 AM
BigD9146gt   Sorry boys, I have some dis-hearting numbers... i...   Feb 1 2005, 11:15 AM
iiibdsiil   Any thoughts as to whether it would be easier to m...   Feb 1 2005, 11:16 AM
cdmcse   Here is another company that makes mechanical cali...   Feb 1 2005, 11:33 AM
SteveSr     Feb 1 2005, 11:49 AM
BigD9146gt   Hey iibdsiil, Get rid of that rock and go to Sear...   Feb 1 2005, 11:54 AM
SteveSr     Feb 1 2005, 11:56 AM
Mueller     Feb 1 2005, 12:34 PM
cdmcse   Anybody know the width of a vented rotor and toler...   Feb 1 2005, 01:27 PM
BigD9146gt   cdmcse, the early-SC (late 60?-83) vented is 20mm ...   Feb 1 2005, 01:31 PM
Aaron Cox   inboard spot caliper idea rocks. arent 911 cv/axle...   Feb 1 2005, 01:34 PM
andys   ...   Feb 1 2005, 01:40 PM
BigD9146gt   EDIT: Bondo is right, the 911's are shorter th...   Feb 1 2005, 01:43 PM
Aaron Cox     Feb 1 2005, 01:43 PM
Aaron Cox   ...   Feb 1 2005, 01:49 PM
andys   ...   Feb 1 2005, 02:24 PM
scooter311   SteveSr got me thinking (there I go working withou...   Feb 1 2005, 02:36 PM
SteveSr   <...   Feb 1 2005, 07:45 PM
iiibdsiil   Wow, that is pretty well thought out and looks lik...   Feb 1 2005, 07:47 PM
Aaron Cox   ...   Feb 1 2005, 07:49 PM
bondo   That looks pretty much like my plan for mounting t...   Feb 1 2005, 07:53 PM
BIGKAT_83   Wilwood also makes a drum brake setup like the 911...   Feb 1 2005, 08:37 PM
scott thacher   aaron, your drawing is basicly what i thought of w...   Feb 1 2005, 08:41 PM
Maltese Falcon   Hey guys and gals, I'll be finishing off the W...   Feb 1 2005, 09:24 PM
BigD9146gt   Maltese, you wouldn't happen to have a drawing...   Feb 1 2005, 09:40 PM
Maltese Falcon   Don, I've adapted the horizontal fan "As is" f...   Feb 1 2005, 11:34 PM
Mueller   do you have any sound files of that motor?   Feb 2 2005, 07:30 AM
iamchappy   Ive been considering the e brake for some time now...   Feb 2 2005, 07:31 AM
94teener   A picture of the Wilwood spot brake install.   Feb 2 2005, 09:41 AM
joea9146   Looks great.... Did you Fabricate the Bracket ? Is...   Feb 2 2005, 09:45 AM
Maltese Falcon   Clay, you're right on the money with needing o...   Feb 2 2005, 09:46 AM
ClayPerrine   <...   Feb 2 2005, 09:50 AM
joea9146   ...   Feb 2 2005, 01:32 PM
iiibdsiil   So how much do you think the bracket is going to c...   Feb 2 2005, 01:44 PM
ClayPerrine   It won't come with spacers. If I do this, it w...   Feb 2 2005, 01:55 PM
Mueller   Hey Clay... 1:1 scale copies in a word or pdf fil...   Feb 2 2005, 02:06 PM
iiibdsiil   If they are that easily accessible (the spacers) t...   Feb 2 2005, 02:38 PM
Mueller   ...   Feb 2 2005, 02:43 PM
Aaron Cox     Feb 2 2005, 02:45 PM
Aaron Cox   EDIT2: also... who made the above one? EDIT3: als...   Feb 2 2005, 02:48 PM
iiibdsiil   I'm not gonna argue over a couple pounds of un...   Feb 2 2005, 02:49 PM
ClayPerrine   The caliper mounts UNDER the rotor. That way you c...   Feb 2 2005, 02:55 PM
Aaron Cox   okay. thanks clay. that looks like a winning solut...   Feb 2 2005, 02:57 PM
ClayPerrine   I am not going to supply the calipers. You have to...   Feb 2 2005, 03:00 PM
andys   Clay, Another question came to mind. How does th...   Feb 2 2005, 03:41 PM
Mueller   Billet Spot Caliper Here you go....takes a while...   Feb 2 2005, 04:07 PM
andys     Feb 2 2005, 05:39 PM
Mueller   dang, you are right...time for a visit to my eye d...   Feb 2 2005, 05:42 PM
ClayPerrine     Feb 3 2005, 07:05 AM
DuckRyder   That looks intresting. I do have one question as f...   Feb 3 2005, 07:25 AM
ClayPerrine   ...   Feb 3 2005, 07:37 AM
DuckRyder   Ahh I see, 1) Isn't a problem here 2) I sup...   Feb 3 2005, 08:26 AM
ClayPerrine   When I said "over time" I mean within an hour. M...   Feb 3 2005, 08:42 AM
andys
- Lo-Fi Version Time is now: 2nd April 2026 - 12:57 PM
