> 914-6 Fuse panel questions, Need a digital pic, please
mikey
post Jan 31 2005, 02:20 AM
Does anyone have a picture of a 914-6 fuse panel they could post? I'm re-installing mine after replacing the harness and new style fuse block. I've got 4 relays (3 round ones and 1 square one) and 4 mounting holes on the fuse panel. But I'm not sure which relay goes in which hole. My manual only shows a 914-4 fuse panel.
sixnotfour
post Feb 1 2005, 02:37 PM
The Diagram I have that matched your ignition Question, shows ;
1 addtional headlight relay .
2 headlamp flasher.
3 horn relay,
4 square turn indicator and hazard warnig flasher unit
Will it go in location D in Wolfgangs 6 pic.?
Hpoe this Helps , Jeff (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif)
mikey   914-6 Fuse panel questions   Jan 31 2005, 02:20 AM
propricer   Will try to get pix and / or info by tomorrow. Ed ...   Jan 31 2005, 09:58 AM
mikey   Thanks Ed! http://www.91...   Jan 31 2005, 10:46 AM
Gustl   not sure if this helps, this is out from the facto...   Jan 31 2005, 11:30 AM
Gustl   914-6: A - buzzer B - fog lamps C - horn   Jan 31 2005, 11:33 AM
Gustl   I added both types because you wrote about 3 round...   Jan 31 2005, 11:35 AM
mikey     Jan 31 2005, 12:06 PM
propricer   I'm assuming that Wolfgang has answered your q...   Feb 1 2005, 10:22 AM
mikey   Ed, I'll be passing through Morgan Hill on th...   Feb 1 2005, 01:25 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:14 PM
