| Tdskip |
Sep 19 2024, 04:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
As I am sure many of you can identify with after having several project cars I have ended up with a metric ton of spare parts. I need to get my working space decluttered so it is time to have these parts find people that can use them.
I will try to start posting a list of what I have but everything will be free or nearly free (think pizza money). I'll am planning on being at the shop in Santa Ana from 8-9:30 |
| Tdskip |
Sep 21 2024, 07:45 AM
OK - trying again. Sorry for the trouble people;
914 front suspension with uprights and good rotors 911 headers believed from a 2.4 911 doors (non-power windows) 914 good door 914 not so good door 911 vented rotor front calipers from a 1971 (believe good but not run) 914 front brake cores (might be OK but sitting long time) Mostly intact 914 wiring harness Three 914 axle cores High torque starter core Side shifter shift rod for under car Muffler hangers for 1.8 and 2.0 Rain trays Charcoal canisters for various set ups Front valence 1.8 engine core (assume on rebuilding) Core transmission missing 1st gear cluster, known to be good otherwise Front shocks Misc FI bits Used coil and plug wiring Crankshaft Several 914/6 rear bumpers in various condition / good cores or scruffy driver condition Headlight motors Various rubber trim bits A-arm front suspension (various) 5 run axles 1976 smog pump Various lifters Jack stands One 2.0L heat exchanger 911 headers believed to be for 2.4l Rear valences Oh, and a 914/6 build, a rusty but workable 911 Targa, and a 1966 Alfa GT Spring Veloce (aka Stepnose) shell* * these are not free and a whole lots of pizzas While the idea is to clear space some of these parts clearly have some value so please be at least slightly reasonable in how much pizza offered. Most of the small bits will be free for the taking. Out of respect for your fellow 914 owners place only take free things you can use or that will advance family/friends projects. |
| Ron914 |
Sep 21 2024, 08:45 AM
Member ![]() ![]() Group: Members Posts: 492 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
OK - trying again. Sorry for the trouble people; 914 front suspension with uprights and good rotors 911 headers believed from a 2.4 911 doors (non-power windows) 914 good door 914 not so good door 912 front calipers from a 1971 (believe good but not run) 914 front brake cores (might be OK but sitting long time) Mostly intact 914 wiring harness Three 914 axle cores High torque starter core Side shifter shift rod for under car Muffler hangers for 1.8 and 2.0 Rain trays Charcoal canisters for various set ups Front valence 1.8 engine core (assume on rebuilding) Core transmission missing 1st gear cluster, known to be good otherwise Front shocks Misc FI bits Used coil and plug wiring Crankshaft Several 914/6 rear bumpers in various condition / good cores or scruffy driver condition Headlight motors Various rubber trim bits A-arm front suspension (various) 5 run axles 1976 smog pump Various lifters Jack stands One 2.0L heat exchanger 911 headers believed to be for 2.4l Rear valences Oh, and a 914/6 build, a rusty but workable 911 Targa, and a 1966 Alfa GT Spring Veloce (aka Stepnose) shell* * these are not free and a whole lots of pizzas While the idea is to clear space some of these parts clearly have some value so please be at least slightly reasonable in how much pizza offered. Most of the small bits will be free for the taking. Out of respect for your fellow 914 owners place only take free things you can use or that will advance family/friends projects. Good morning Tom , I am very interested in the 1976 smog pump . I've been trying to get my 76 back on the road and I need that smog pump here in California to try again to get my car to pass smog so I can get it registered. I am in Huntington Beach so I can pick up here in So Cal Ron |
| bdstone914 |
Sep 21 2024, 07:55 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Ron914
Most rods are bent. I have a jig and can straighten them. I will be there tomorrow. If your rod is off the car bring it. If you get a rod feom Tom i can check it too. The coupler needs to be removed. Bruce |
| Ron914 |
Sep 21 2024, 10:58 PM
@Ron914 Most rods are bent. I have a jig and can straighten them. I will be there tomorrow. If your rod is off the car bring it. If you get a rod feom Tom i can check it too. The coupler needs to be removed. Bruce Hello Bruce ,I just saw your reply and I don't think I will be able to remove my shift bar from the car before. heading over in the morning but since you have jig maybe I can drive out to your place sometime and have you check it for me .I will talk to you about it in the morning . Ron |
Tdskip Free and almost free parts in SoCal this Sunday Sep 19 2024, 04:49 PM
wertygrog If you come across a passenger footwell foam block... Sep 19 2024, 04:54 PM
bdstone914
If you come across a passenger footwell foam bloc... Sep 19 2024, 05:40 PM
Tdskip Hi folks - will get at least of partial list if it... Sep 20 2024, 06:54 AM
Dynosoar11 Thanks I cant wait to see whats availible. Sep 20 2024, 08:08 AM
lbubba42614 Can't waitto see what you have Sep 20 2024, 10:51 PM
Stratfink Hey Tom. I’ll be in San Clemente this weekend an... Sep 21 2024, 12:48 AM
Ron914
... Sep 21 2024, 11:34 AM
Ron914 PM sent for smog pump Sep 21 2024, 09:03 AM
bdstone914 I am interested in:
914 front suspension with upr... Sep 21 2024, 09:42 AM
a914luvr I could really use a rear valance! Sep 21 2024, 10:16 AM
bdstone914
The ine... Sep 21 2024, 06:58 PM
Tdskip https://maps.app.goo.gl/BJ1KPsyfntyHhwwy5?g...ps.p... Sep 21 2024, 10:45 AM
Dynosoar11 Rear valence needed
are we first come first served... Sep 21 2024, 11:21 AM
Tdskip Hi folks - appreciate all the messages and interes... Sep 21 2024, 12:27 PM
Puebloswatcop Id like the mostly intact 914 Wiring Harness..
If... Sep 21 2024, 01:50 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Sep 21 2024, 07:00 PM
Puebloswatcop
@[url=http://www.914world.com/bbs2/index.php?show... Sep 22 2024, 11:10 AM
ndfrigi Nice Tom you share parts you don’t need anymore.... Sep 21 2024, 08:33 PM
a914luvr 2nd this! I came away with a few much needed p... Sep 22 2024, 11:41 AM
Tdskip Looking forward to seeing everyone soon.
Added tw... Sep 22 2024, 07:57 AM
Tdskip RE: Free and almost free parts in SoCal this Sunday Sep 22 2024, 09:23 AM
ValcoOscar Thank you Tom
Nice to see you this morning.
GOOD ... Sep 22 2024, 11:52 AM
Dynosoar11 Thanks Tom
nice meeting you Sep 22 2024, 12:02 PM
Ron914 Thank you again Tom ,
I can't say enough about... Sep 22 2024, 02:42 PM
Tdskip Great to see everyone today, I am happy some of wh... Sep 22 2024, 09:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:05 PM |
