| Chad911sc |
Sep 24 2024, 10:00 AM
Member ![]() ![]() Group: Members Posts: 293 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
Thanks for all your replies in advance….
I’m new to the type I4 engine and I am building a 2.0 liter GA motor. I have come to understand that a proper build of this type is very dependent on the combination. I’ve built several engines over the years but all of them were V8’s except my first build at the age of 15, which was a type 1 beetle. I bought this 74 914 about 3 months ago and it ran fine with 93,000 miles on it. As far as I know it’s totally stock, but it was puking oil from every orifice. My plan was to pull it out and reseal it. After getting it out I noticed that there was considerable oil around the base of the cylinders and at the meeting of the heads. I pulled the heads off to clean it up and reseal it, but after my best friend looked at the heads ( he owns his own cylinder head shop) he said they were garbage. Cracks around spark plug holes and at every surface where it meets the cylinders. My budget didn’t include an engine rebuild, so I bit the bullet and ordered a set of heads from AA that are standard valve sizes. I know this is a Chinese product, but whatever needs addressing on these heads he will take care of for free. He is cleaning up the intakes and polishing them, and porting and polishing the exhaust side for me. I also ordered 96mm pistons and cylinders from AA as well. I will also have those checked and sized as needed. I am at the point where I have to figure out the cam profile. I have read for weeks about all the different companies and different cams out there. I am leaning towards the Jake Rabi deluxe cam kit that comes with everything I need. Just want to know which one would be the right fit for me. The car will be a mostly weekend car for me, but I want it to have good driving characteristics as well. Looking more for torque and not some high hp numbers. I have a set of webbers 40mm that came with the car and I am hoping to be able to use these if possible. I’m not changing the exhaust at this time and it is SS headers with a Monza exhaust. Thanks again for your time, Chad. |
| Jack Standz |
Sep 24 2024, 01:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 743 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Consider a Webcam with a grind appropriate for your use. Get matching Webcam lifters. Don't mix & match different hardnesses on camshafts and lifters.
Crower springs work for us. If your friend doesn't have experience with porting 914/Type IV heads, maybe it's best to leave the heads alone, particularly since you're not looking for ultimate performance. Thse without such experience are likely to make flow worse, not better. Best wishes for your project! |
Chad911sc Cam choice for 2056 dual carb build Sep 24 2024, 10:00 AM
GregAmy I'm running an 86A in my 2056 racer with 40 De... Sep 24 2024, 10:30 AM
rfinegan Great place to start looking with carbs and street... Sep 24 2024, 02:01 PM
rfinegan Great place to start looking with carbs and street... Sep 24 2024, 02:02 PM
930cabman Give Dema a call at Elgin cams. Probably the best ... Sep 24 2024, 02:14 PM
Chad911sc Thanks for all the info so far!
I have had my ... Sep 24 2024, 02:33 PM
930cabman BTW
:wttc:
sounds like a great project and a g... Sep 24 2024, 06:03 PM
Chad911sc Yeah I bought this one to just drive it and not ha... Sep 24 2024, 06:38 PM
barefoot Building my 2056 with about 8.5 CR stock 2L valve ... Sep 25 2024, 08:03 AM
Chad911sc Thanks for the input barefoot. Thats what I’m lo... Sep 25 2024, 01:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 06:06 PM |
