| NARP74 |
Oct 4 2024, 05:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,448 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I was starting to balance my carbs, never looked into them since I bought the car. I ran into some issues with my carbs vs the standard docs I find.
One bank reads 4.5 and 5, the other bank reads 6 and 6 with the snail. When I looked into adjusting the lower reading one, I noticed some odd looking adjustment options. I was expecting to see an air bypass, idle mixture and vacuum port on both sides. I only have it on one side. Pic below. The side missing the air bypass happens to be the lowest reading of all 4 carbs, so how do I adjust that one? Carbs are numbered, 40 IDF 42/43 4C on the base of both. ![]() |
| Superhawk996 |
Oct 5 2024, 11:07 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,881 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Make sure the idle air bypass screw on the 5 bore is fully closed.
Bring 4.5 / 5 bank up to 6 ish using the adjust screw on the side that affects both throttle bores. Readjust idle mixture as needed. Alternatively you can bring the bank with 6’s down. Which way you go depends on where each set of throttle plates are at. You need to ensure the transition ports don’t get uncovered at idle. Example, if bringing 4.5 / 5 back up to 6 is uncovering the transition port, then you must bring the bank of 6’s down. |
NARP74 Weber Oct 4 2024, 05:45 PM
Shivers Mine are 40’s but mine have the same adjustments... Oct 5 2024, 12:39 AM
NARP74 I was expecting symmetry. I can't find any ot... Oct 5 2024, 08:16 AM
infraredcalvin NM i read the question wrong… Oct 5 2024, 11:55 AM
NARP74 I pulled one carb off and got some answers, not on... Oct 5 2024, 12:44 PM
technicalninja I have a possible inexpensive route for you.
Look... Oct 5 2024, 12:54 PM
NARP74 That link is to a utube vid about AFR and engine c... Oct 5 2024, 10:19 PM
930cabman
Make sure the idle air bypass screw on the 5 bore... Oct 6 2024, 07:20 AM
MikeK
Make sure the idle air bypass screw on the 5 bore... Oct 6 2024, 11:38 AM
technicalninja Updated my post to reflect CORRECT target.
You... Oct 6 2024, 11:42 AM
NARP74 After a full refresh, not rebuild, the air and num... Oct 10 2024, 12:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 06:23 PM |
