| technicalninja |
Oct 5 2024, 04:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Trying to wrap my head around what size spacers (range) I should be looking for to utilize stock 99 Boxster wheels on a "standard" flared 914.
Fronts are 17X7 ET 55 Rears are 17X8.5 ET 50 Any suggestions? |
| slowrodent |
Oct 6 2024, 11:08 AM
Member ![]() ![]() Group: Members Posts: 245 Joined: 29-February 20 From: Tucson/Oro Valley Member No.: 23,981 Region Association: Southwest Region
I went out for a 2nd look. Rear is a tight finger clearance right now, but tires are pretty straight up and down.. Rear alignment should help quite a bit. Front with tires pointed straight is probably a loose finger clearance (1/2") but I'll likely reduce that with the spacer swap as indicated above...
technicalninja Boxster wheel fitment Oct 5 2024, 04:01 PM
sixnotfour What is A standard flair ?? no flair/GT flair Oct 6 2024, 08:23 AM
slowrodent I suppose I have what would be standard flares, bu... Oct 6 2024, 09:45 AM
technicalninja
I... Oct 6 2024, 11:17 AM
slowrodent Oops duh... 245/50-17 and 215/50-17 Oct 6 2024, 11:18 AM
technicalninja
I went out for a 2nd look. Rear is a tight finger... Oct 6 2024, 11:21 AM
JamesM
Trying to wrap my head around what size spacers (... Oct 6 2024, 11:31 AM
technicalninja
[quote name='technicalninja' post='3171334' date=... Oct 6 2024, 12:12 PM
JamesM
1st question the "daily" tires that are... Oct 6 2024, 12:55 PM
slowrodent I agree that the front 3" seems pretty extrem... Oct 6 2024, 12:27 PM
Chris914n6 In the front I use 21mm 944 spacers on 17x7 and th... Oct 6 2024, 06:07 PM
Chris914n6 I test fit a 9x17 255/40 under my rolled rears. Id... Oct 12 2024, 08:23 PM
technicalninja @Chris914n6
Before I saw your pic of a 9 on stock... Oct 12 2024, 09:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th September 2026 - 06:52 PM |
