| technicalninja |
Oct 5 2024, 04:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Trying to wrap my head around what size spacers (range) I should be looking for to utilize stock 99 Boxster wheels on a "standard" flared 914.
Fronts are 17X7 ET 55 Rears are 17X8.5 ET 50 Any suggestions? |
| JamesM |
Oct 6 2024, 11:31 AM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,304 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Trying to wrap my head around what size spacers (range) I should be looking for to utilize stock 99 Boxster wheels on a "standard" flared 914. Fronts are 17X7 ET 55 Rears are 17X8.5 ET 50 Any suggestions? First, what size tires? Second, as already asked, what do you mean by "standard"? Is that a stock narrow body or steel GT flares? Third, assuming you are talking GT flares is how flush do you want the wheels with the fenders? Depending on tire width you are going to need minimum a 20mm spacer in the front for the 7s to clear the front struts. 8.5s most likely are not going to fit a narrow body rear, assuming you are talking GT flares than 33mm minimum to clear the inside. These are both the MINIMUM you need to clear the inside assuming your tire size is not wider than the rim. If you are running GT flares then you may want to make these larger to fill the fenders. Exactly how much larger depends on the look you want, the tire you are running, and the measurements of your specific car. |
technicalninja Boxster wheel fitment Oct 5 2024, 04:01 PM
sixnotfour What is A standard flair ?? no flair/GT flair Oct 6 2024, 08:23 AM
slowrodent I suppose I have what would be standard flares, bu... Oct 6 2024, 09:45 AM
slowrodent I went out for a 2nd look. Rear is a tight finger ... Oct 6 2024, 11:08 AM
technicalninja
I... Oct 6 2024, 11:17 AM
slowrodent Oops duh... 245/50-17 and 215/50-17 Oct 6 2024, 11:18 AM
technicalninja
I went out for a 2nd look. Rear is a tight finger... Oct 6 2024, 11:21 AM
technicalninja
[quote name='technicalninja' post='3171334' date=... Oct 6 2024, 12:12 PM
JamesM
1st question the "daily" tires that are... Oct 6 2024, 12:55 PM
slowrodent I agree that the front 3" seems pretty extrem... Oct 6 2024, 12:27 PM
Chris914n6 In the front I use 21mm 944 spacers on 17x7 and th... Oct 6 2024, 06:07 PM
Chris914n6 I test fit a 9x17 255/40 under my rolled rears. Id... Oct 12 2024, 08:23 PM
technicalninja @Chris914n6
Before I saw your pic of a 9 on stock... Oct 12 2024, 09:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th September 2026 - 06:52 PM |
