> ET vs Backspacing, What the...
Krieger
post Oct 8 2024, 06:14 PM
I am going to order some new wheels for my track car. 15 x 9. I understand backspacing. I think all 911 and 914/6 backspacing stock is 125mm. That is what I'd like. The manufacturer is listing three different ETs: 3mm, 10.6, 23.3. Which ET gives me the stock backspacing?
technicalninja
post Oct 9 2024, 09:18 AM
QUOTE(JamesM @ Oct 8 2024, 10:59 PM) *
QUOTE(SirAndy @ Oct 8 2024, 11:24 PM) *
Found this in the info listed on an online calculator.
Not sure how accurate it is but it assumes that a 9" wheel is actually wider than 9" if you account for the wheel "lip".
Once you have your wheel width, it’s common practice to add an inch to it to account for the wheel’s outer lips before dividing it by two.
Wheel width is supposed to be measured tire bead to tire bead.
If you've got a 9" wheel it should be 9" between the beads, not total width of the wheel.
JamesM's wheel calculators state the same thing.
So, if you're close you should actually measure what you've got and NOT trust published widths.
Some wheels have skinny lips, and some are fat.
Adding an inch overall should be "safe" in most cases.
- Lo-Fi Version Time is now: 2nd April 2026 - 07:43 PM
