> 1976 fuel injection questions
914incali
post Apr 2 2024, 11:07 AM
Picked up a 76 out of texas that had been converted to single carb that just doesn't run very well. I decided to convert back to original FI, essentially everything is gone and I am working on understanding the system. I guess my first question is where does the fuel pump draw power from? there is a single black wire underneath the fuel tank that has no power to it but all the relays have been removed and Im waiting on those from pelican
wonkipop
post Oct 9 2024, 08:06 PM
@Ron914
here is what CARB would have on file for the 76.
its all the bits they are looking for listed with part numbers.
can't see that part number of the item mr. b has posted.
but i am sure it will be there somewhere somehow.
mr. b would know.
they are noting some items enrichment sensor and pressure sensor.
whether these are the same thing not sure.
not really up on the old D jet or the complications of CARB emissions.
i do know that all the components are shared from 75 to 76 and do not change.
ie a 75 calif = a 76 calif.
and a 75 49 states = a 76 49 s.
but the big thing is that a 75 calif and 75 49 states are different beasts.
Ron914
post Oct 10 2024, 04:58 PM
QUOTE(wonkipop @ Oct 9 2024, 09:06 PM) *
@Ron914
mr. b would know.
Thank you bothT for your advice ,this was not the news I was hoping to hear . I somehow assumed since this was a 49 state car that has been continuously registered and smogged for 34 years in California that as long as I had all the original equipment installed and working it would pass a smog check as it has since 1985 . I have spent more than I thought on this car than I thought to get back on the road and I'm starting to think I should just try to sale in another state and look for another one .I am going to just take it in to a star station and see what happens and if its possible to get a wavier as a 49 state car . I wish I could ask the previous owner how he was getting it to pass a smog check for 34 years but that is not possible .
fiacra
post Oct 10 2024, 11:14 PM
Person.Woman.Man.Camera.TV.
QUOTE(Ron914 @ Oct 10 2024, 03:58 PM) *
@Ron914
You don't need a waiver. I have brought a 49 state car into California before (not a 914) and at the time I was told that as long as it is labeled as a Federally compliant car and not labeled as a car originally sold in California it will not be disqualified for not having the California smog package installed on it. You still have to pass the smog check and meet all the emissions requirements. The car must have all of its original equipment on it (for example, it cannot have been converted to carbs). My advice is that if you are ready to try and get it smogged, go for it. Give it a good run on the freeway and make sure it is fully warmed up and not sitting before being tested. Obviously it must be in good tune. If you fail the test the first time just look at the numbers and tune it from there. For example, if the HC is high then lean out the mixture a bit until you get it right. You can play with the timing to affect the numbers, or change the heat range on the spark plugs, etc. I went through this with a '79 Super Beetle with L-Jet, and it took seven tries but I did get it to pass. I then sold it as quick as I could (IMG:style_emoticons/default/biggrin.gif) . Here's the link to that thread on the Samba if you want to see what I went through with that car.
https://www.thesamba.com/vw/forum/viewtopic...03348a6294adfdb
Lots of information and advice on the Samba about how to pass the CA smog check, but it will all be about L-Jet. Nonetheless you might find it helpful.
I know there is at least one member in SoCal who has a '76 that they swear passes smog check every two years without problems. You might be able to do the same. But just remember you will have to smog it every two years and if you have trouble this time you can bet it won't get easier.
Here's the link to find out the smog history for your car. All you need is the license plate number. It won't tell you where it was tested, but it will tell you when it was tested and if it passed. I routinely check that when I'm looking at a used car. If it has a number of failed tests I keep looking.
https://www.bar.ca.gov/inspection
914incali   1976 fuel injection questions   Apr 2 2024, 11:07 AM
dr914@autoatlanta.com   power is from the relay board in the engine compar...   Apr 2 2024, 11:18 AM
914incali   I have a complete injection system and am waiting ...   Apr 2 2024, 11:34 AM
rjames   Black and red= power, brown=ground to chassis.   Apr 2 2024, 11:54 AM
914incali   Black and red= power, brown=ground to chassis. ...   Apr 2 2024, 12:12 PM
JeffBowlsby   Single brown ground cable for the fuel pump is se...   Apr 2 2024, 01:15 PM
914incali   yes its out of a 73 2.0, im not to worried about s...   Apr 2 2024, 01:31 PM
fiacra   yes its out of a 73 2.0, im not to worried about ...   Apr 2 2024, 10:02 PM
L-Jet914   yes its out of a 73 2.0, im not to worried about ...   Oct 10 2024, 11:33 PM
burton73   The problem is you are in California, and you need...   Apr 2 2024, 01:39 PM
Karl R   Also that is the wrong FI for your car. Your 1976...   Apr 3 2024, 07:04 PM
JeffBowlsby   Also that is the wrong FI for your car. Your 197...   Apr 3 2024, 07:23 PM
wonkipop   Also that is the wrong FI for your car. Your 19...   Apr 4 2024, 06:10 PM
Ron914   [quote name='JeffBowlsby' post='3137731' date='Ap...   Oct 9 2024, 12:42 PM
wonkipop   [quote name='JeffBowlsby' post='3137731' date='A...   Oct 9 2024, 04:15 PM
L-Jet914   [quote name='JeffBowlsby' post='3137731' date='A...   Oct 10 2024, 11:17 PM
r_towle   76 is djet. I happen to have one here if you need...   Apr 3 2024, 08:23 PM
Karl R   I guess I'm starting to slip. I thought they s...   Apr 4 2024, 04:39 PM
r_towle   I guess I'm starting to slip. I thought they ...   Apr 4 2024, 05:31 PM
JeffBowlsby   For smog purposes CA-only model 1975-76 914s also ...   Oct 9 2024, 05:15 PM
wonkipop   @Ron914 here is what CARB would have on file for...   Oct 9 2024, 08:06 PM
Ron914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Oct 10 2024, 04:58 PM
wonkipop   well i can only speak as an australian down here...   Oct 10 2024, 06:57 PM
fiacra   [quote name='wonkipop' post='3172034' date='Oct 9...   Oct 10 2024, 11:14 PM
Ron914   [quote name='wonkipop' post='3172034' date='Oct ...   Oct 10 2024, 11:47 PM
L-Jet914   [quote name='fiacra' post='3172200' date='Oct 11 ...   Oct 10 2024, 11:57 PM
wonkipop   [quote name='fiacra' post='3172200' date='Oct 11 ...   Oct 11 2024, 12:41 AM
JeffBowlsby   Did paperwork from the previous smog tests come wi...   Oct 10 2024, 05:28 PM
wonkipop   on the question of how the previous owner got the ...   Oct 10 2024, 07:07 PM
wonkipop   @JeffBowlsby you always throw up interesting inf...   Oct 10 2024, 07:22 PM
JeffBowlsby   Yes! It’s in the Service &Training manu...   Oct 10 2024, 07:48 PM
JeffBowlsby   I have at least one 75 CA 2.0L with the SL box on ...   Oct 10 2024, 07:58 PM
wonkipop   I have at least one 75 CA 2.0L with the SL box on...   Oct 10 2024, 09:44 PM
JeffBowlsby   [quote name='JeffBowlsby' post='3172179' date='Oc...   Oct 10 2024, 10:15 PM
wonkipop   [quote name='JeffBowlsby' post='3172179' date='O...   Oct 11 2024, 12:38 AM
Ron914   When I bought the car I had to go to the DMV and p...   Oct 10 2024, 10:47 PM
L-Jet914   If you have a plate number you can see the pass/fa...   Oct 10 2024, 11:03 PM
L-Jet914   Everything required for a California certified 197...   Oct 10 2024, 11:28 PM
wonkipop   Everything required for a California certified 19...   Oct 11 2024, 12:39 AM
930cabman   Glad I don't live in Cali   Oct 11 2024, 05:04 AM
fiacra   Glad I don't live in Cali It ain't bad ...   Oct 11 2024, 03:29 PM
emerygt350   Absolutely agree. Drives me crazy living in NY tr...   Oct 11 2024, 06:35 PM
davep   So Ron, what is the current situation?   Jan 5 2025, 03:30 PM
fiacra   @914incali [b]@[url=http://www.914world.com/bbs2...   Jan 5 2025, 03:57 PM
Ron914   Thanks for checking in . I am still working on my ...   Jan 6 2025, 12:28 PM
Ron914   I believe it was @ emerygt350 that asked @slapsho...   Jan 6 2025, 12:35 PM
JeffBowlsby   Post a photo of that oblong hole so we clearly und...   Jan 6 2025, 12:48 PM
rjames   Post a photo of that oblong hole so we clearly un...   Jan 6 2025, 02:02 PM
emerygt350   If the idle adjust screw no longer closes off the ...   Jan 6 2025, 02:54 PM
Ron914   I would really like to post a photo or video but l...   Jan 6 2025, 04:44 PM
burton73   I would really like to post a photo or video but ...   Jan 6 2025, 06:19 PM
Ron914   [quote name='Ron914' post='3185256' date='Jan 6 2...   Jan 6 2025, 06:37 PM
burton73   Sending this to Rick as well. You are very close...   Jan 6 2025, 09:28 PM
emerygt350   You are all good with that butterfly. That is how...   Jan 6 2025, 06:08 PM
Ron914   You are all good with that butterfly. That is ho...   Jan 6 2025, 07:04 PM
technicalninja   Thanks Bob!   Jan 7 2025, 09:20 AM
rjames   The butterfly should have two screws that hold t...   Jan 7 2025, 11:05 AM
emerygt350   The butterfly should have two screws that hold ...   Jan 7 2025, 12:47 PM
Ron914   The butterfly should have two screws that hold...   Jan 7 2025, 02:34 PM
emerygt350   At the current state I would leave it in the hole,...   Jan 7 2025, 07:56 PM
Ron914   Hello , I covered the inside idle screw air intake...   Jan 11 2025, 06:12 PM
emerygt350   Great news. What a nice looking car! Just ou...   Jan 11 2025, 07:18 PM
Ron914   Great news. What a nice looking car! Just o...   Jan 11 2025, 08:00 PM
fiacra   Good luck on Monday. Fingers crossed. If it does...   Jan 11 2025, 07:41 PM
JeffBowlsby   You might also try a smoke pen/pencil. Lower inve...   Jan 11 2025, 08:48 PM
emerygt350   Is your vacuum retard can on the distributor hooke...   Jan 11 2025, 09:24 PM
Ron914   Is your vacuum retard can on the distributor hook...   Jan 12 2025, 09:23 AM
Ron914   Lets try the photo again   Jan 12 2025, 09:39 AM
JeffBowlsby   Hose 10 is not connected to anything on a 1974-76 ...   Jan 12 2025, 09:53 AM
Ron914   Hose 10 is not connected to anything on a 1974-76...   Jan 12 2025, 10:22 AM
Ron914   I don't think that this is the source of my va...   Jan 12 2025, 10:23 AM
Ron914   should the #10 hose be plugged or left open to air...   Jan 12 2025, 10:24 AM
Ron914   should the #10 hose be plugged or left open to ai...   Jan 12 2025, 10:32 AM
rjames   [quote name='Ron914' post='3186354' date='Jan 12 ...   Jan 12 2025, 12:54 PM
Ron914   When I first assembled my motor I followed this di...   Jan 12 2025, 10:40 AM
Ron914   When I first assembled my motor I followed this d...   Jan 12 2025, 10:56 AM
emerygt350   We should walk you through all the vacuum hoses. ...   Jan 12 2025, 02:02 PM
emerygt350   We should walk you through all the vacuum hoses. ...   Jan 12 2025, 02:05 PM
Ron914   We should walk you through all the vacuum hoses....   Jan 12 2025, 02:58 PM
rjames   ‘75/76 2.0 cars did not have the PCV valve.   Jan 12 2025, 02:37 PM
emerygt350   ‘75/76 2.0 cars did not have the PCV valve. ...   Jan 12 2025, 03:50 PM
emerygt350   And... That decel keeps you from blowing out your ...   Jan 12 2025, 03:54 PM
JeffBowlsby   Good point that this is a ‘76 car, the 75-76 car...   Jan 12 2025, 07:32 PM
Ron914   Hi Jeff , Yes ,as I mentioned I have a federally c...   Jan 12 2025, 08:04 PM
emerygt350   They were always trying different things to handle...   Jan 12 2025, 08:31 PM
Ron914   They were always trying different things to handl...   Jan 12 2025, 08:40 PM
emerygt350   Anyone got a good 76 vacuum map? I am always nerv...   Jan 12 2025, 08:33 PM
Ron914   The exciting thing for me is we believe this is a ...   Jan 12 2025, 08:54 PM
Ron914   Hello @914incali I also have a 76 914 I am tryin...   Jan 12 2025, 09:40 PM
Ron914   @emerygt350 I think this will be my last post in ...   Jan 14 2025, 09:35 AM
emerygt350   Yes, probably a good idea. But you know now that ...   Jan 14 2025, 03:36 PM
Ron914   Yes, probably a good idea. But you know now that...   Jan 14 2025, 04:18 PM
emerygt350   Your car doesn't have an advance port, that wo...   Jan 14 2025, 04:30 PM
emerygt350   If you have your advance hose hooked to any kind o...   Jan 14 2025, 04:32 PM
Ron914   If you have your advance hose hooked to any kind ...   Jan 14 2025, 08:24 PM
emerygt350   That is good news. Progress! I will wait for...   Jan 15 2025, 06:25 AM
brant   Please don’t “Time by ear” Remark the timi...   Jan 15 2025, 10:53 AM
Ron914   Please don’t “Time by ear” Remark the tim...   Jan 15 2025, 11:28 AM
914werke   I started updating this one based on an unmolested...   Jan 15 2025, 11:17 AM
Ron914   I started updating this one based on an unmoleste...   Jan 15 2025, 12:30 PM
- Lo-Fi Version Time is now: 15th November 2026 - 02:50 AM
