| FlacaProductions |
Oct 12 2024, 07:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,176 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I've done a lot of reading on this - prepping to re-install the decal valve. I have a good valve and new hoses.
Does this picture show correct routing? ie: "side" port going to the top/side of the airbox. (pic originally from @TJB/914) ![]() |
JeffBowlsby The early 74s 2.0 are like the 73s with the charco... Oct 12 2024, 07:57 PM
FlacaProductions Understood. Thank you, Jeff! Oct 12 2024, 09:31 PM
FlacaProductions I'm confused @JeffBowlsby
Went out to do the... Oct 13 2024, 06:08 PM
JeffBowlsby The 75-76 air plenums have different port sizes as... Oct 13 2024, 06:53 PM
JeffBowlsby 73-74 Note the two side port relative sizes. Oct 13 2024, 07:54 PM
JeffBowlsby 75-76 - Smaller side port (it appears to have a c... Oct 13 2024, 07:56 PM
FlacaProductions Yup - appears i have a later plenum.
Interesting.... Oct 14 2024, 06:36 AM
JeffBowlsby Or find the correct 73-74 plenum.
Or maybe there ... Oct 14 2024, 08:07 AM
emerygt350 Yeah. As long as you have manifold at the top, fre... Oct 14 2024, 03:39 PM
dr914@autoatlanta.com front and rear ports to vacuum side port to air cl... Oct 14 2024, 03:46 PM
dr914@autoatlanta.com also the air cleaner and sheet metal should be sem... Oct 14 2024, 03:47 PM
emerygt350 Engine release cable? That sounds dangerous! Oct 14 2024, 04:30 PM
FlacaProductions Thanks for all of this input.
My time in Indiana... Oct 14 2024, 07:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 10:48 PM |
