| Gearup |
Oct 17 2024, 02:20 PM
Member ![]() ![]() Group: Members Posts: 165 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None |
Looking for input.
Found rust inside my gas tank and curious what people use to clean and seal. I purchased evaporust and am going to use that after a good washout. What have you used that worked well? Also, aside from POR 15 fuel tank sealer what products have you used that you thought worked well or found not to? Lastly, sealer recommendation, rust removal tactics and quantity of sealant needed to coat a 914 tank. Thank you very much for any advice/input. Brett |
| dr914@autoatlanta.com |
Oct 17 2024, 02:58 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
take it to a radiator shop and if they cannot handle it, buy a new tank, we have many on the shelf and they are cheap and already powder coated
Looking for input. Found rust inside my gas tank and curious what people use to clean and seal. I purchased evaporust and am going to use that after a good washout. What have you used that worked well? Also, aside from POR 15 fuel tank sealer what products have you used that you thought worked well or found not to? Lastly, sealer recommendation, rust removal tactics and quantity of sealant needed to coat a 914 tank. Thank you very much for any advice/input. Brett |
| bkrantz |
Oct 17 2024, 06:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,646 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
take it to a radiator shop and if they cannot handle it, buy a new tank, we have many on the shelf and they are cheap and already powder coated Looking for input. Found rust inside my gas tank and curious what people use to clean and seal. I purchased evaporust and am going to use that after a good washout. What have you used that worked well? Also, aside from POR 15 fuel tank sealer what products have you used that you thought worked well or found not to? Lastly, sealer recommendation, rust removal tactics and quantity of sealant needed to coat a 914 tank. Thank you very much for any advice/input. Brett Those are becoming very rare, especially shops that will "boil out" fuel tanks. My son needs one for his MR2 track car project and can't find one. |
Gearup Rust inside gas tank Oct 17 2024, 02:20 PM
mepstein Best is to thoroughly clean and fill back up with ... Oct 17 2024, 02:33 PM
bdstone914 I just cleaned a tank and used 5 gallons of evapor... Oct 17 2024, 02:47 PM
JmuRiz
I just cleaned a tank and used 5 gallons of evapo... Oct 17 2024, 03:16 PM
technicalninja https://www.autohausaz.com/pn/14383934-JP-1...AiAB... Oct 17 2024, 03:00 PM
DC_neun_vierzehn
https://www.autohausaz.com/pn/14383934-JP-1...AiA... Oct 18 2024, 12:21 PM
pglotzbecker Mine is currently at a metal cleaning business loc... Oct 17 2024, 05:14 PM
nivekdodge I did seal mine with one of the kit's on the f... Oct 17 2024, 06:25 PM
Gearup
The tank has been modified for my LS3 with an i... Oct 17 2024, 09:08 PM
targa72e I have used electrolysis with good results. All yo... Oct 17 2024, 09:41 PM
rick 918-S
I have used electrolysis with good results. All y... Oct 17 2024, 11:28 PM
Gearup
I have used electrolysis with good results. All y... Oct 18 2024, 04:08 AM
bkrantz
I have used electrolysis with good results. All ... Oct 18 2024, 07:34 PM
worn
I have used electrolysis with good results. All y... Oct 18 2024, 05:03 PM
rjames After getting my tank boiled, I rinsed it inside a... Oct 18 2024, 09:02 AM
DC_neun_vierzehn The tank on my 73 was pretty grungy inside. I put ... Oct 18 2024, 09:13 AM
technicalninja I did purchase my tank over a year ago and shippin... Oct 18 2024, 01:49 PM
Puebloswatcop I have used Muriatic Acid with great success. It ... Oct 19 2024, 12:35 PM
mepstein Once it’s clean, you can dump a bottle of MMO, m... Oct 19 2024, 03:20 PM
targa72e Did you seal the tank afterwards or leave it bare?... Oct 20 2024, 10:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:30 PM |
