> OT - Any HVAC Types around?, Vents, point which way?
DuckRyder
post Feb 1 2005, 08:02 PM
Avatars Mode: OFF because of the recalcitrant few.
O.K. heres the question:
In my house all of the vent louvres point toward an outside wall (and they are all near a wall) as a result, it usually feels real warm by the wall and real not warm in the room.
Is there a proper way to determine which way a vent points, and what is it.
(I'm talking about the downstairs, and the vents are in the roof, I don't ever go upstairs and there isn't any bitching from up there, so it must not need fidling with)
Thanks in advance for any enlightenment. [wheres the blanket smilie?]
SpecialK
post Feb 1 2005, 10:24 PM
aircraft surgeon
QUOTE (DuckRyder @ Feb 1 2005, 06:47 PM)
The heat exchanger for the downstairs unit sits in the upstairs closet, it draws its air from a vent in the kitchen ceiling. The roof is a high slope and the ducting runs in the eves created by the upstairs rooms (does that make sense) the vents are in the ceiling along the two long walls.
Great set up for cooling (drawing the hot air off of the ceiling), not so good for heating (same reason it's good for cooling).
Sounds like you need to figure out some way to get a return air duct down low to suck up some of that cooler air at floor level.
Pics....yes, pics..
DuckRyder   OT - Any HVAC Types around?   Feb 1 2005, 08:02 PM
r_towle   if I understand you correctly, you have hvac ducts...   Feb 1 2005, 08:27 PM
SpecialK   Most houses I've seen run what is called "peri...   Feb 1 2005, 08:39 PM
DuckRyder   THANKS! See I knew there was someone here tha...   Feb 1 2005, 08:47 PM
SpecialK   ...   Feb 1 2005, 10:24 PM
DJsRepS   In fla we dont cool off our windows to cool our ho...   Feb 15 2005, 05:37 AM
Bleyseng   For heating you heat the coldest thing in the room...   Feb 15 2005, 06:22 AM
guywan914   In the notheast we tend to favor the heating load ...   Feb 15 2005, 05:42 PM
DuckRyder   Ho, I forgot about this, it is warmer now
- Lo-Fi Version Time is now: 15th July 2025 - 04:11 AM
