wheel bearing question |
mightyohm |
Feb 1 2005, 09:18 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
I am having a front wheel bearing adjustment issue:
If I tighten my front wheel bearings to the point where I can just barely slide the thrust washer around with a screwdriver, and I still have a clunk when I rock the wheel back and forth, what does that mean? If I tighten the clamp nut about 15 degrees more, the clunk disappears, but the thrust washer won't budge unless I pry against it. I have read this is a no-no - the thrust washer should slide around easily without prying. Are my wheel bearings shot? The outer bearing looks fine and I repacked it with grease... This is a 911 front suspension if it makes any difference. |
Otmar |
Feb 1 2005, 10:49 PM
2000 Amps in a 914 Group: Members Posts: 174 Joined: 3-March 03 From: Corvallis, OR, USA Member No.: 387 |
Mine have the same problem, despite being new bearings. I think the spindles are undersize from years of bad bearings.
One thing to check is how snug the inner bearing races fit on the spindle. Any play there will still be there after a proper bearing adjustment. It's annoying. Next time I plan to lightly knurl the spindle for a tighter fit. With a centerpunch. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 06:13 AM |
