| Mueller |
Jan 31 2005, 09:56 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Doing some "surf'n" and came across these being installed on an Audi A4
I never knew that they made a parking brake caliper... Attached image(s)
| Maltese Falcon |
Feb 2 2005, 09:46 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,209 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Clay, you're right on the money with needing only one spot caliper to stop the car...on my 930 turbo a small 1/8"section of the ebrake spring broke off inside the drum and you could NOT even push the car (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
Sound byte of the horiz fan will eventually be on the msdsinc. site> working on it. It does idle with about 80 Db of evilness (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Chap, since we're so off topic, PM me and I'll give you some good pointers on the IC set-up. If you want to go thru (cut) the trunk lid, start with a donor trunk ! Marty |
Mueller Brembo cable actuated parking brake.. Jan 31 2005, 09:56 PM
Mueller one more shot..... Jan 31 2005, 09:56 PM
iiibdsiil Someone please have pricing and it better be cheap... Jan 31 2005, 10:25 PM
cdmcse I am seriously considering using these....
Wilwoo... Jan 31 2005, 10:36 PM
scott thacher here is a simply way to make a parking brake. buy ... Jan 31 2005, 11:06 PM
bondo Jan 31 2005, 11:29 PM
ArtechnikA
