| drmitch |
Nov 16 2024, 05:23 PM
Member ![]() ![]() Group: Members Posts: 57 Joined: 7-October 13 From: So California Member No.: 16,485 Region Association: Southern California |
Hello all,
I just picked up my first Porsche a week ago and it's a 1972 914 survivor in great condition. As I've been tinkering with it, I'm finding that the fog light design is a bit nuts, in my opinion. That damn clip that's supposed to hold the lens trim ring in place has me beat. What I'd like to do is install aftermarket lights that would look similar to Jeff Zwart's rally lights on his 914. They don't have to be Cibies. The point of this would be to have likely better lighting and a design that's far easier to change a bulb!!! Any guidance from someone who has done this would be much appreciated. Mitch |
| Literati914 |
Nov 19 2024, 02:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,236 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
@Literati914 - I believe the LEDs that @dtmehall is referring to are for his Pilots. I have the same/similar. draw is probably each - they don't pull much at all. Though he never said he had pilots, only referred to original lights AND also said he bought H3 LEDs that fit the housing. Does @drmitch mean those H3 leds fit the original fog light housings? WOW! An abundance of great info here. That said, I'm still not entirely clear on some things. The whole impetus for my inquiry was the infuriating design of the clip that I understand as holding the lens ring in place. I don't see how that works and frankly, I don't want to know. I want a much-improved replacement. In addition, the passenger side lens is cracked, the bulb socket has subsequently been wet over the years, and the bulb has fused to the socket. The Pilot/914Werkes lights appear to be a near identical replacement in terms of appearance. What I don't understand at all is how they would be installed. I see a bracket; does that require that a hole be drilled for a bolt? If not, then how exactly are these lights swapped in for the OEM? As for electrical, these lights plug right into the existing wiring? Perhaps if one of you has a PDF of the installation instructions or can guide me to a video of installation, I'd get some clarity. In the end, I don't intend to drive at night and most certainly not in fog. I want to do this to a. maintain the original aesthetic of the car and b. use them as daytime driving lights for better visibility to other drivers. As an interim solution, I just received a pair of non-fog light horn grills from Auto Atlanta so that the car will look good until the fog light replacement is figured out. THANK YOU ALL!!! And of course the above ^ indicates that he does not have the pilot (style) lights. Again, @drmitch , what housings are you saying those H3 leds fit? |
drmitch Aftermarket fog lights in stock location? Nov 16 2024, 05:23 PM
Front yard mechanic Just tape flashlights to the hood works great Nov 16 2024, 08:48 PM
Steve Pilot lights are the most popular.
http://www.auto... Nov 16 2024, 09:04 PM
drmitch
http://www.aut... Nov 17 2024, 06:41 PM
dtmehall skip aa.
if you want a light that someone has ac... Nov 16 2024, 09:42 PM
FlacaProductions :agree: Nov 17 2024, 09:37 AM
chriselkjar
skip aa.
if you want a light that someone has a... Nov 17 2024, 02:08 PM
drmitch Thanks to all. Regarding the 914Werks lights, wha... Nov 17 2024, 04:45 PM
SirAndy ... what's the difference between the driving ... Nov 17 2024, 05:08 PM
worn
... what's the difference between the driving... Nov 17 2024, 06:34 PM
SirAndy Maybe I can learn something. I think of fog light... Nov 17 2024, 07:16 PM
914werke Thanks to all. Regarding the 914Werks lights, ... Nov 17 2024, 05:15 PM
drmitch
Thanks to all. Regarding the 914Werks lights, ... Nov 17 2024, 06:29 PM
dtmehall I should have included this in my previous post. I... Nov 17 2024, 05:27 PM
dtmehall the halogen bulbs that come with the lights are ri... Nov 17 2024, 05:28 PM
dtmehall just to be clear, the fog vs driving light differe... Nov 17 2024, 07:21 PM
FlacaProductions I've posted this before - but these are Pilots... Nov 17 2024, 07:22 PM
dtmehall Brian
Pilots or 914Werke lights?
Dan Nov 17 2024, 07:31 PM
FlacaProductions Mine are Pilots and Pilots are what 914Werke is se... Nov 17 2024, 08:57 PM
914werke Mine are Pilots and Pilots are what 914Werke is s... Nov 18 2024, 11:55 AM
double-a i installed Hella 118 on mine, split fluted lens w... Nov 18 2024, 02:19 PM
Spoke If you wanted to use the OEM foglight fixtures, yo... Nov 18 2024, 02:26 PM
Jamie
If you wanted to use the OEM foglight fixtures, y... Nov 19 2024, 01:46 PM
Literati914
I should have included this in my previous post. ... Nov 19 2024, 12:35 PM
FlacaProductions @Literati914 - I believe the LEDs that [b]@[url=... Nov 19 2024, 01:52 PM
drmitch WOW! An abundance of great info here. That s... Nov 19 2024, 02:03 PM
drmitch
[quote name='FlacaProductions' post='3177915' dat... Nov 19 2024, 03:34 PM
914werke Here is how they are attached to the chassis on al... Nov 19 2024, 02:48 PM
drmitch
Here is how they are attached to the chassis on a... Nov 19 2024, 03:33 PM
dtmehall Hopefully this post clears up the questions
1. I ... Nov 19 2024, 05:30 PM
drmitch
1. I... Nov 19 2024, 05:41 PM
dtmehall One more thing, my car is a 73 1.7 Nov 19 2024, 05:45 PM
Literati914 @dtmehall and [b]@[url=http://www.914world.com/... Nov 19 2024, 06:27 PM
dtmehall :toke: Nov 19 2024, 06:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:09 AM |
