| captjm |
Nov 22 2024, 09:03 PM
Newbie ![]() Group: Members Posts: 16 Joined: 28-January 07 From: Temecula, CA Member No.: 7,485 |
I need some help with wiring a 914 fuel pump being relocated to the front fuel tank location exactly like the 75/76 914's. The car is a 1971 914/4 being set up for a carbureted 2.4 six cylinder. My question is about where to pick up the power to run the pump correctly.
I would like it to have any relay protections like the original if that is the way it is suppose to be. I think the positive power is to come from the engine compartment relay board from the forward connector pin 13? I plan on running the positive wire from pin 13 under the driver side rocker panel forward to to the fuel tank bay and picking up the ground from the closest grounding point nearest to the tank bay. Any comments or advice would be helpful. Thank you |
| JeffBowlsby |
Nov 26 2024, 10:47 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
That's excellent Clay. Better safe than sorry.
I am not an EE, but I pointed out the factory harness 12GA wire design for those wanting to relocate the pump, because Porsche originally engineered it that way so it is a good precedent. I imagine that it was a conservative approach considering all factors that could be encountered at the time - electrical draw of the pumps available then, plus effects of greater resistance over time, heat degradation, etc., plus a safety factor. If todays pumps create less load then great, but anyone contemplating that relocation should be aware of the wire size and be prepared to replace that pump when necessary with a similarly efficient pump to avoid overheating the wire and inform the next owner also. The fuse for the FP circuit is the big 25A fuse on the relay board. Adding a secondary fuse inline...not sure how that will behave. |
captjm Fuel pump relocation and wiring Nov 22 2024, 09:03 PM
dtmehall it was 40 years ago when i did this. i believe you... Nov 22 2024, 09:12 PM
JeffBowlsby It’s a 12 ga wire. Nov 22 2024, 09:32 PM
dtmehall it was 12 gauge for the fuel injection pump. i wou... Nov 22 2024, 09:38 PM
davep
it was 12 gauge for the fuel injection pump. i wo... Nov 24 2024, 12:24 PM
North Coast Jim I ran the wire thru the tunnel wired as above. Bou... Nov 24 2024, 08:22 AM
North Coast Jim I ran a two conductor wire thru the tunnel wired a... Nov 24 2024, 08:25 AM
dtmehall below is a website to calculate wire size based on... Nov 24 2024, 07:00 PM
SirAndy If you still have the original wiring the fuel pum... Nov 24 2024, 07:26 PM
bkrantz
If you still have the original wiring the fuel pu... Nov 24 2024, 08:42 PM
dtmehall That's a good idea. It wasn't possible in ... Nov 24 2024, 07:36 PM
worn
That's a good idea. It wasn't possible in... Nov 24 2024, 07:43 PM
worn
That's a good idea. It wasn't possible i... Nov 24 2024, 07:44 PM
ClayPerrine If you pull the fuel pump wire back and reroute it... Nov 25 2024, 08:34 AM
JeffBowlsby Prob with that Clay is that the 70-74 FP wire is o... Nov 25 2024, 09:33 AM
ClayPerrine
Prob with that Clay is that the 70-74 FP wire is ... Nov 26 2024, 07:30 AM
Literati914
If you pull the fuel pump wire back and reroute i... Nov 25 2024, 04:29 PM
dtmehall This thread started when captjm said that he wante... Nov 25 2024, 05:50 PM
Literati914
The fuse for the FP circuit is the big 25A fus... Nov 26 2024, 11:23 AM
JeffBowlsby The 25A fuse is the main fuse for the entire car, ... Nov 26 2024, 11:24 AM
Literati914
The 25A fuse is the main fuse for the entire car,... Nov 26 2024, 11:29 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd April 2026 - 04:17 AM |
