> Brembo cable actuated parking brake.., hmmm...wonder what these cost?? :)
Mueller
post Jan 31 2005, 09:56 PM
914 Freak!
Doing some "surf'n" and came across these being installed on an Audi A4
I never knew that they made a parking brake caliper...
ClayPerrine
post Feb 2 2005, 01:55 PM
It won't come with spacers. If I do this, it will be just the brackets. The spacers are from the local Ace Hardware store. The brackets are made from 6061-T6 aluminum, and the holes are tapped for M-8 x1.25 bolts.
I may just get the G-code files and put them here for anyone to grab.
Mueller   Brembo cable actuated parking brake..   Jan 31 2005, 09:56 PM
Mueller   one more shot.....   Jan 31 2005, 09:56 PM
iiibdsiil   Someone please have pricing and it better be cheap...   Jan 31 2005, 10:25 PM
cdmcse   I am seriously considering using these.... Wilwoo...   Jan 31 2005, 10:36 PM
scott thacher   here is a simply way to make a parking brake. buy ...   Jan 31 2005, 11:06 PM
bondo     Jan 31 2005, 11:29 PM
ArtechnikA     Feb 1 2005, 09:52 AM
bondo   Our 87 Subaru GL-10 has it's parking brake in ...   Feb 1 2005, 10:53 AM
BigD9146gt   Sorry boys, I have some dis-hearting numbers... i...   Feb 1 2005, 11:15 AM
iiibdsiil   Any thoughts as to whether it would be easier to m...   Feb 1 2005, 11:16 AM
cdmcse   Here is another company that makes mechanical cali...   Feb 1 2005, 11:33 AM
SteveSr     Feb 1 2005, 11:49 AM
BigD9146gt   Hey iibdsiil, Get rid of that rock and go to Sear...   Feb 1 2005, 11:54 AM
SteveSr     Feb 1 2005, 11:56 AM
Mueller     Feb 1 2005, 12:34 PM
andys     Feb 1 2005, 01:21 PM
cdmcse   Anybody know the width of a vented rotor and toler...   Feb 1 2005, 01:27 PM
BigD9146gt   cdmcse, the early-SC (late 60?-83) vented is 20mm ...   Feb 1 2005, 01:31 PM
Aaron Cox   inboard spot caliper idea rocks. arent 911 cv/axle...   Feb 1 2005, 01:34 PM
andys   ...   Feb 1 2005, 01:40 PM
BigD9146gt   EDIT: Bondo is right, the 911's are shorter th...   Feb 1 2005, 01:43 PM
Aaron Cox     Feb 1 2005, 01:43 PM
Aaron Cox   ...   Feb 1 2005, 01:49 PM
andys   ...   Feb 1 2005, 02:24 PM
scooter311   SteveSr got me thinking (there I go working withou...   Feb 1 2005, 02:36 PM
SteveSr   <...   Feb 1 2005, 07:45 PM
iiibdsiil   Wow, that is pretty well thought out and looks lik...   Feb 1 2005, 07:47 PM
Aaron Cox   ...   Feb 1 2005, 07:49 PM
bondo   That looks pretty much like my plan for mounting t...   Feb 1 2005, 07:53 PM
BIGKAT_83   Wilwood also makes a drum brake setup like the 911...   Feb 1 2005, 08:37 PM
scott thacher   aaron, your drawing is basicly what i thought of w...   Feb 1 2005, 08:41 PM
Maltese Falcon   Hey guys and gals, I'll be finishing off the W...   Feb 1 2005, 09:24 PM
BigD9146gt   Maltese, you wouldn't happen to have a drawing...   Feb 1 2005, 09:40 PM
Maltese Falcon   Don, I've adapted the horizontal fan "As is" f...   Feb 1 2005, 11:34 PM
Mueller   do you have any sound files of that motor?   Feb 2 2005, 07:30 AM
iamchappy   Ive been considering the e brake for some time now...   Feb 2 2005, 07:31 AM
94teener   A picture of the Wilwood spot brake install.   Feb 2 2005, 09:41 AM
joea9146   Looks great.... Did you Fabricate the Bracket ? Is...   Feb 2 2005, 09:45 AM
Maltese Falcon   Clay, you're right on the money with needing o...   Feb 2 2005, 09:46 AM
ClayPerrine   <...   Feb 2 2005, 09:50 AM
joea9146   ...   Feb 2 2005, 01:32 PM
iiibdsiil   So how much do you think the bracket is going to c...   Feb 2 2005, 01:44 PM
Mueller   Hey Clay... 1:1 scale copies in a word or pdf fil...   Feb 2 2005, 02:06 PM
iiibdsiil   If they are that easily accessible (the spacers) t...   Feb 2 2005, 02:38 PM
Mueller   ...   Feb 2 2005, 02:43 PM
Aaron Cox     Feb 2 2005, 02:45 PM
Aaron Cox   EDIT2: also... who made the above one? EDIT3: als...   Feb 2 2005, 02:48 PM
iiibdsiil   I'm not gonna argue over a couple pounds of un...   Feb 2 2005, 02:49 PM
ClayPerrine   The caliper mounts UNDER the rotor. That way you c...   Feb 2 2005, 02:55 PM
Aaron Cox   okay. thanks clay. that looks like a winning solut...   Feb 2 2005, 02:57 PM
ClayPerrine   I am not going to supply the calipers. You have to...   Feb 2 2005, 03:00 PM
andys   Clay, Another question came to mind. How does th...   Feb 2 2005, 03:41 PM
Mueller   Billet Spot Caliper Here you go....takes a while...   Feb 2 2005, 04:07 PM
andys     Feb 2 2005, 05:39 PM
Mueller   dang, you are right...time for a visit to my eye d...   Feb 2 2005, 05:42 PM
ClayPerrine     Feb 3 2005, 07:05 AM
DuckRyder   That looks intresting. I do have one question as f...   Feb 3 2005, 07:25 AM
ClayPerrine   ...   Feb 3 2005, 07:37 AM
DuckRyder   Ahh I see, 1) Isn't a problem here 2) I sup...   Feb 3 2005, 08:26 AM
ClayPerrine   When I said "over time" I mean within an hour. M...   Feb 3 2005, 08:42 AM
andys
- Lo-Fi Version Time is now: 2nd April 2026 - 11:17 AM
