> Fuel line routing below/above shelf with SS lines
s13u74cr4
post Nov 30 2024, 04:09 PM
Based on community knowledge gathered in a previous post it turns out the PO of my 73 2.0 had the supply and return lines reversed underneath. I now have ALL NEW hoses AND the correct fuel filter AND a reducer pipe from Tangerine, but want to make sure I am right before I start cutting the lines.
Going off this diagram:
(IMG:https://bowlsby.net/914/Classic/zTN_FI_Hose_FuelPump_1970-74.jpg)
If I use the measurements there I will have too much in some spots and too little in others. I am guessing these numbers are not based of having SS lines? Does it matter is I have more/less in runs between connections?
And, I believe the SS lines above the shelf are correct. Supply in front and return in the rear. On the underside you can see where that positions them which is tight.Attached Image
mlindner
post Dec 2 2024, 08:38 AM
I'm also a fan of having the fuel pump up front, and easy access. Best, MarkAttached Image
- Lo-Fi Version Time is now: 25th November 2026 - 06:46 PM
