| cgnj |
Dec 3 2024, 10:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 740 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None
I have always wanted to do ITB FI for my 2270. I found a box in my stash of parts with a DRLA 45 with one of the air bypass screws stripped. I found this thread on STFSTF IDF/DRLA to throttle body.. I guess I would have to block off everything above the throttle plate, and machine my manifolds to for injectors. Feedback on this idea is appreciated
| cgnj |
Dec 4 2024, 09:48 PM
Actually, What started me on this was many years ago I read this threadStock 2.0l plenum and runners on 2270, It will flow enough air I just opened the box with all the parts I collected for this. It also has a 2.1 water boxer plenum (reworked to accept 914 throttle cable) and the TB. Then I started working on my other project cars. They are all finished now so I'm back to disabling a good running 2270 motor.
Availability of reasonably priced ITBs is the problem. CB appears to be the only company with them. Can't be ordered from Mario atm. If @GregAmy decides to sell his stash, I would be in the market. Good article regarding your microsquirt conversion. You should post it here so it can go into the Lapuwali Classic Thread Forum. |
cgnj Converting IDF/DRLA to throttle body Dec 3 2024, 10:01 PM
technicalninja Once you get the venturi and the booster out you w... Dec 3 2024, 10:43 PM
mb911
Once you get the venturi and the booster out you ... Dec 4 2024, 11:16 AM
VaccaRabite I mostly agree with Ninja - except on the part abo... Dec 4 2024, 05:59 AM
emerygt350 Yeah, for simplicity the single can't be beat.... Dec 4 2024, 08:38 AM
technicalninja I HOPE they don't use stock Miata throttle bod... Dec 4 2024, 09:49 AM
technicalninja
Not necessarily. I use my triple Webers as TBs an... Dec 4 2024, 12:20 PM
emerygt350
[quote name='mb911' post='3180180' date='Dec 4 20... Dec 4 2024, 05:57 PM
mb911
[quote name='mb911' post='3180180' date='Dec 4 20... Dec 4 2024, 07:57 PM
GregAmy If you're reeeeeellly interested in doing this... Dec 4 2024, 04:24 PM
GregAmy If GregAmydecides to sell his stash, I would be in... Dec 4 2024, 10:07 PM
JamesM
On a big-cam 2.4? Yeah, probably. But on this o... Dec 5 2024, 01:50 AM
JamesM to many posts to respond to each one individually ... Dec 5 2024, 02:31 AM
GregAmy Im going to guess your 2056 is built to somewhere ... Dec 5 2024, 08:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th November 2026 - 11:38 AM |
