| cgnj |
Dec 3 2024, 10:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 740 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None
I have always wanted to do ITB FI for my 2270. I found a box in my stash of parts with a DRLA 45 with one of the air bypass screws stripped. I found this thread on STFSTF IDF/DRLA to throttle body.. I guess I would have to block off everything above the throttle plate, and machine my manifolds to for injectors. Feedback on this idea is appreciated
| JamesM |
Dec 5 2024, 02:31 AM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,348 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
to many posts to respond to each one individually so ill try to summarize my points to keep this as short as possible.
1. Quad 45mm throttle plates is a LOT of air to try an modulate on a 2.3. Your throttle is going to be pretty touchy, especially around tip in and you most likely wont have decent enough vacuum to run a speed-density fueling algorithm properly so you will be stuck with alpha-n which is sub optimal. If you keep the vents and choke them down to ~40 or less you might be ok, but you still have a 45mm throttle plate... might as well just start with 40mm ITBs to begin with. 2. You don't need an IAC. When a motor is tuned properly an IAC does absolutely nothing at idle. They can compensate for for a bad tune or other issues the motor can be having but that is not necessarily a good thing as they then MASK problems you might otherwise be aware of. These cars run just fine fixed timing at idle but additional idle stabilization can be had just via timing control, no IAC needed. 3. IACs with ITBs can potentially be problematic. In order to get enough air flow though the IAC to the individual cylinders to make a difference you have to run a pretty big line to each of them from a distribution block which then connects all your runners. This then allows the intake stroke from one cylinder to pull air/fuel from another disrupting the mixture of individual cylinders. In addition most ITB setups for type 4s place the injector in the throttle bodies themselves near the throttle plate leaving the only place to add lines for the IAC BELOW THE INJECTOR!!! This means air can now flow under the fuel charge rather than through it which can be especially problematic if you attempt to rely solely on airflow through the IAC for starting. 4. Depending on the ECU and fueling algorithm you use you DONT need a TPS for acceleration enrichment. On a speed density based system with decent vacuum signal rate of throttle change can be calculated via rate of manifold vacuum change. I can show you datalogs where the TPS state and manifold vacuum state mirror each other perfectly. That said I would still choose to run a TPS and it should be considered mandatory if you are going to run 45mm ITBs as you will most likely have to run Alpha-n. 5. @GregAmy I would suspect you will have a worse experience if you convert from d-jet plumbing to ITBs and potentially may even loose torque and tuneability. Might benefit power if you had more cam but with your current setup I suspect the cons will outweigh the pros. And then we have this... (IMG:style_emoticons/default/smile.gif) |
cgnj Converting IDF/DRLA to throttle body Dec 3 2024, 10:01 PM
technicalninja Once you get the venturi and the booster out you w... Dec 3 2024, 10:43 PM
mb911
Once you get the venturi and the booster out you ... Dec 4 2024, 11:16 AM
VaccaRabite I mostly agree with Ninja - except on the part abo... Dec 4 2024, 05:59 AM
emerygt350 Yeah, for simplicity the single can't be beat.... Dec 4 2024, 08:38 AM
technicalninja I HOPE they don't use stock Miata throttle bod... Dec 4 2024, 09:49 AM
technicalninja
Not necessarily. I use my triple Webers as TBs an... Dec 4 2024, 12:20 PM
emerygt350
[quote name='mb911' post='3180180' date='Dec 4 20... Dec 4 2024, 05:57 PM
mb911
[quote name='mb911' post='3180180' date='Dec 4 20... Dec 4 2024, 07:57 PM
GregAmy If you're reeeeeellly interested in doing this... Dec 4 2024, 04:24 PM
cgnj Actually, What started me on this was many years a... Dec 4 2024, 09:48 PM
GregAmy If GregAmydecides to sell his stash, I would be in... Dec 4 2024, 10:07 PM
JamesM
On a big-cam 2.4? Yeah, probably. But on this o... Dec 5 2024, 01:50 AM
GregAmy Im going to guess your 2056 is built to somewhere ... Dec 5 2024, 08:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th November 2026 - 11:38 AM |
