| dlindzey |
Dec 4 2024, 04:38 PM
repeat offender ![]() ![]() Group: Members Posts: 53 Joined: 8-April 14 From: texas Member No.: 17,226 Region Association: Southwest Region |
I think it is a brake warning light and from what I have read it subserves two functions. If still on after the engine starts either parking brake is on or you have brake failure. In my case parking brake is not on and brakes seem to work ok. It came on a few months ago and then went off and I thought might be a short so I have just not used the parking brake for months. Today it is on again and won't go off.
There is not much working space around the parking brake so I never did find the little button that is activated/deactivated for the parking brake. Anyone know what I am talking about or have any suggestions for trouble shooting the matter? TIA dll-----I forgot 1971 model |
| Ishley |
Dec 5 2024, 11:55 AM
Member ![]() ![]() Group: Members Posts: 363 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
70-72 have the older style parking brake handle which has a Pivot in the middle to make it easier to get in and out of the car. The part that triggers the parking brake look different. I modified mine with an adjustable screw that triggers the switch.
dlindzey brake warning light Dec 4 2024, 04:38 PM
dtmehall The parking brake function, using the flasher rela... Dec 4 2024, 06:11 PM
fiacra Check the brake fluid reservoir to make sure that ... Dec 4 2024, 06:22 PM
jim_hoyland FYI- The switch for the e-Brake is identical to yo... Dec 4 2024, 07:25 PM
StarBear
FYI- The switch for the e-Brake is identical to y... Dec 5 2024, 09:19 AM
dtmehall jim_hoyland
how did you do that? did you take the... Dec 4 2024, 07:29 PM
jim_hoyland
jim_hoyland
how did you do that? did you take th... Dec 4 2024, 07:51 PM
brant The switch for the parking brake can fail
It is ... Dec 4 2024, 07:59 PM
dlindzey
It is... Dec 5 2024, 05:40 PM
Ishley Pull the seat all the way forward. On the track o... Dec 4 2024, 08:00 PM
Spoke The MC warning switch and ebrake switch are in par... Dec 5 2024, 09:09 AM
FlacaProductions The switch is activated/pressed on by the circled ... Dec 5 2024, 10:03 AM
FlacaProductions ahhh, yes -that pic I posted is for later cars - a... Dec 5 2024, 12:00 PM
brant Isn’t the reservoir in the front trunk?
Not th... Dec 5 2024, 05:50 PM
emerygt350 You can get at the mc switch by just removing or e... Dec 5 2024, 05:53 PM
brant
You can get at the mc switch by just removing or ... Dec 5 2024, 06:13 PM
brant The next job step becomes more difficult
You nee... Dec 5 2024, 06:16 PM
dlindzey thank you everybody for the advice and been there ... Dec 6 2024, 09:22 AM
brant
thank you everybody for the advice and been there... Dec 7 2024, 08:22 AM
fiacra That was a nice write-up Brant. That is exactly h... Dec 7 2024, 10:28 AM
dlindzey thank you gentlemen, I would assume that everythin... Dec 7 2024, 12:24 PM
Literati914 Does your "fasten Seat Belts" light work... Dec 7 2024, 02:45 PM
dlindzey
Does your "fasten Seat Belts" light wor... Dec 7 2024, 09:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th September 2026 - 04:22 AM |
