> Serpentine Belt-- Updated Thread, Clewitt System Install Photos
Robarabian
post Aug 26 2023, 03:46 PM
914 A Roo
Ok, here is my stab at an installation thread.
1) I am a home mechanic, not the Red Barn. Please be constructive, I am sure there are several better ways, but this is what I did and it works... at least so far.
2) You will see a red fan and a silver fan. I had to switch them in the end, for alignment purposes. I haven't figured out why yet.
3) I love the way it turned out.
Here goes nothing...:
You start by removing your pulleys from both the fan and the crank. The crank one goes on easy, and I used a new bolt that I bought with the kit from Clewitt.
The instructions say to make sure there are no burrs on your fan. This is important. It was a tight fit, I ended up doing a bit of sanding and cleaning up the fan pulley area to get the Clewitt pulley to fit on and off. It says you can use shims to make sure everything is straight.
I used my 911 cam chain straight edge that I got from Stomski Racing to line up the pulleys.
Once you know they are in alignment, you need to mount the tensioner. In my case, I had to fabricate a bracket. On the left side, the tins would be in the way on my particular engine. I used the right side mount bolt.
Note: Clewitt's tensioner is on an eccentric, so it can be tensioned from either side, it is a universal as far as that goes. It works at about any angle.
I used a beefy angle mount I had, and a piece of straight / flat bar. After measuring it up, I mig welded both sides, and ground em down a bit since I am not a super welder.
I drilled the mounting holes and mounted it up. Once it is in place, I fiddled with where I wanted it. I notched my angle mount so it would sort of catch my engine mount and lock into place to avoid any rotation due to tension. I got lucky here.
After test fitting it and tensioning it, I shortened one end and then painted it black. Clewitt pre-threads it, so I noticed the tensioner wasn't in perfect alignment. I used a few washers between the mount I made and the tensioner to shim it forward slightly and it popped into perfect alignment.
It looks pretty slick and the belt change is as simple as loosening the eccentric bolt, rotating the tensioner either direction and removing the belt. You re-tension it and allow for 1/4 inch deflection. Richard Clewitt said not to over tension it, or you can either put wear on the alternator bearing or the tensioner, but he said it is designed that the tensioner will fail before an alternator bearing. Replacements are pretty cheap.
You shouldn't have to fabricate anything if you are using the Rich Johnson type mount, as it has the provisions for the tensioner to bolt directly to. This is just what I had to do.
See photos.
Attached Image Attached ImageAttached Image Attached Image Attached Image Attached ImageAttached Image Attached Image
Montreal914
post Dec 6 2024, 02:30 PM
...will discuss this in a different thread. My questions relate more to the installation of the Naro mount. Thanks.
Robarabian   Serpentine Belt-- Updated Thread   Aug 26 2023, 03:46 PM
ClayPerrine   Ok, here is my stab at an installation thread. ...   Aug 26 2023, 03:56 PM
Robarabian   I sent the photos to Clewitt to get his opinion. I...   Aug 26 2023, 03:58 PM
jim_hoyland   Nice presentation Rob :)   Aug 26 2023, 08:33 PM
Cairo94507   I think that is a significant improvement over the...   Aug 27 2023, 08:52 AM
mb911   I would love this setup. Need to sell more oil tan...   Aug 27 2023, 10:19 AM
Robarabian   Ok, I got some feedback from Clewitt, and he also ...   Aug 27 2023, 12:35 PM
arbitrary   @Robarabian how is the tensioner mount working ou...   Dec 1 2024, 05:17 PM
Cairo94507   Congratulations on getting that sorted. We instal...   Dec 2 2024, 09:10 AM
Montreal914   Curious as to what made this installation a custom...   Dec 4 2024, 10:38 AM
Robarabian   Not with the mount I have. I have the one that is...   Dec 4 2024, 10:18 PM
ClayPerrine   What I did on my 2.4L with this same setup is to u...   Dec 5 2024, 07:50 AM
Robarabian   I'd love to see close ups of that Clay. I real...   Dec 5 2024, 08:00 PM
Montreal914   @Robarabian Are you using the Naro mount?   Dec 5 2024, 09:15 AM
Robarabian   Yes. that is the one. I actually really like it fo...   Dec 5 2024, 07:55 PM
live free & drive   The Naro mount puts the engine 1/2” closer to th...   Dec 5 2024, 09:01 PM
Robarabian   That would explain why it was so tight... I think ...   Dec 5 2024, 10:35 PM
mb911   The Naro mount puts the engine 1/2” closer to t...   Dec 6 2024, 09:00 AM
Robarabian   My engine seal, seals fine. It is a newly replaced...   Dec 6 2024, 09:21 AM
mb911   My engine seal, seals fine. It is a newly replace...   Dec 6 2024, 10:14 AM
Montreal914   The Naro mount puts the engine 1/2” closer to ...   Dec 6 2024, 10:24 AM
mb911   [quote name='mb911' post='3180466' date='Dec 6 20...   Dec 6 2024, 11:01 AM
Montreal914   ...will discuss this in a different thread. My que...   Dec 6 2024, 02:30 PM
live free & drive   Just for some tight numbers onthe Naro mount; if y...   Dec 6 2024, 03:12 PM
ClayPerrine   This isn't the exact picture I was looking for...   Dec 7 2024, 07:09 AM
- Lo-Fi Version Time is now: 23rd October 2026 - 04:44 PM
