| fiacra |
Nov 30 2024, 04:23 PM
Person.Woman.Man.Camera.TV. = MCI ![]() ![]() ![]() Group: Members Posts: 708 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
I rarely drive any of my classic vehicles at night, and then usually only because I'm staying out later than I anticipated. However during the shorter winter days I've found myself out after dark more often and given the anemic output of stock headlights an upgrade to better lighting became more important. I started doing research last year and found this thread to be the most helpful:
http://www.914world.com/bbs2/index.php?sho...%20led&st=0 And yes, @rjames , I did read the article (IMG:style_emoticons/default/beerchug.gif) I also consulted with a friend who owns an independent Porsche repair and restoration shop, and he recommended I get a set from vintagecarleds.com. A few other people recommended them, and I started down that route but the $$$ was a bit much to justify at that time. What I ended up doing was finding the upgraded lenses they sell (Hella H4) from a different supplier at a better price and I was going to buy their lights to put in them, essentially recreating the VCm3 set they were selling but for less $$. Instead I ended up getting these bulbs for just over $20 a set from only944.com: https://only944.com/partscatalog/only/ledbulb/ They work, but I wasn't happy with the fit of the bulbs. They fit in the space available, but I can't use the rubber boots and it doesn't appear to me that they make a tight seal. However since I don't drive in the rain, I had a working solution and I wasn't in a rush I thought I'd wait for a sale to upgrade the bulbs to the vintagecarleds bulbs. So here we are, a year later, and since it is Black Friday weekend and these sets are on sale I went back down the rabbit hole. Not sure if anyone will find this helpful, but here is what I came up with: I don't need the Hella H4 lenses, but here they are on Amazon for $43.76 each (plus tax). Be aware that these have the flat profile and the profile on the headlights on our cars is round, if that matters to you. The profile on the Hella lenses from vintagecarlights is also flat. If you want Hella round profile lenses you can get them from Cars245, and probably other suppliers: https://www.amazon.com/HELLA-002395031-Visi...B001G76Q2W?th=1 Here are the Hella lenses on Cars245.com for $32.36 each. You can get 10% off that price over the next few days with code BF2024, so a set of two for a total of $80.50 shipped to the USA. This is the cheapest option I've found for these Hella lenses. Cars245 is also a good suppler for Bosch dual relays for those of us with L-Jet systems as well as Bosch voltage regulators if you need one, or just want one on the shelf for when you will need it. If you don't need the grey rubber boots for the lenses you can get them for a few bucks cheaper. I'm including links for both options. If you have the black rubber boots don't reuse them, especially if you decide to go with halogen lights instead of LEDs. Apparently they can't handle the heat from the new bulbs. https://cars245.com/en/item/hella-1A6002395...sert-headlight/ https://cars245.com/en/item/hella-1A6002395...sert-headlight/ I bought the VCm3 bulbs from vintagecarleds.com for $135.20 for a set, with free shipping, no tax. This is after the black Friday 20% discount (BLK2024). That means if you get their bulbs and buy the Hella lenses (with boots) from Cars245 you would pay a total of $215.20 for the same set that will cost you $247.20 (that's with the black Friday discount) from vintagecarleds, a savings of $32. That might not be a big deal for some people, but I have multiple cars and only one income, so it adds up. You'll save even more after the black Friday discounts expire, although you will overall pay more. If you don't want the Hella lenses there are cheaper options. There are also options for different bulbs. Here's the link to the VMc3 set on vintagecarleds.com, and a link to the bulbs only: https://vintagecarleds.com/shop/7-inch/vcm3...-headlight-kit/ https://vintagecarleds.com/shop/bulbs-only/vcm3-bulbs-only/ Again, lots of options out there. Just sharing the path I took to upgrade my headlights. |
| Mikey914 |
Dec 9 2024, 09:27 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
A resistor is not required on the 914Rubber ones. However, if you have any issues with them not pulling enough load to trigger the fogs, it's a simple process outlined here
https://914rubber-tk.com/doku.php?id=led_he...troubleshooting |
fiacra LED Headlights Nov 30 2024, 04:23 PM
BillC Thank you very much for the information. I've... Nov 30 2024, 04:51 PM
emerygt350 The 914rubber set work great and plug and play. A... Nov 30 2024, 05:02 PM
FlacaProductions
The 914rubber set work great and plug and play. ... Nov 30 2024, 06:43 PM
fiacra
The 914rubber set work great and plug and play. ... Nov 30 2024, 07:25 PM
JeffBowlsby You'll like those VMc3s Broheen.
You've p... Nov 30 2024, 06:05 PM
fiacra
You've ... Nov 30 2024, 07:35 PM
Jamie I installed the Vintage Car VC3500 LED lamps sever... Nov 30 2024, 06:06 PM
StarBear
I installed the Vintage Car VC3500 LED lamps seve... Dec 10 2024, 08:17 AM
technicalninja Arne turned me onto a Toyota factory head light ... Nov 30 2024, 07:46 PM
FlacaProductions the Hella's are available from 914 rubber - th... Nov 30 2024, 07:58 PM
fiacra
the Hella's are available from 914 rubber - t... Nov 30 2024, 10:34 PM
JeffBowlsby Need a single 6mm male tab bent at 45 to 90 degree... Dec 1 2024, 10:54 PM
Chris914n6 FYI- There are 2 H4 versions from Hella, USA spec ... Dec 2 2024, 12:55 PM
fiacra
FYI- There are 2 H4 versions from Hella, USA spec... Dec 9 2024, 01:42 PM
Chris914n6 Don't mistake price for quality, specially fro... Dec 9 2024, 03:24 PM
fiacra
Don't mistake price for quality, specially fr... Dec 9 2024, 05:37 PM
ThinAir I've been interested in LED headlights for awh... Dec 9 2024, 07:53 PM
Cairo94507 I did the Vintage Car LED's in my car too; I w... Dec 10 2024, 09:12 AM
Nogoodwithusernames I did the Vintage Car LED with the Hella lens in m... Dec 10 2024, 11:30 AM
Chris914n6 Post pics of both headlight faces.
It's possi... Dec 10 2024, 01:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:30 PM |
