| Vicioso |
Dec 12 2024, 01:06 PM
Newbie ![]() Group: Members Posts: 10 Joined: 2-July 24 From: Prescott Arizona Member No.: 28,214 Region Association: None |
I replaced my fuel injectors on my 2.0 - 4 and the car will not run it seam's like I'm getting fuel any ideas?
| JeffBowlsby |
Dec 13 2024, 02:21 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
There is a lot in this text that begs more info:
"the fuel sensor or pressure regulator was bad so I had that rebuilt....the car starts but it seams like its running on one cylinder and will not idle at all" -914s do not have a fuel sensor, what is this? -What is the 'pressure regulator'? Are you referring to the manifold pressure sensor (MPS?) or the fuel pressure regulator? The fuel pressure regulator is doubtful to cause a problem. The MPS on the otherhand...is a critical sensor and must be tuned correctly to your engine if it was just rebuilt. Please clarify & elaborate. Have you confirmed that the three fuel injection ground wires in the fuel injection harness (3 pairs of two wires each) at the top rear of the engine case are connected to the ground lug? Any visibly broken wires in your fuel injection harness? |
Vicioso 914 2.0 injector issues Dec 12 2024, 01:06 PM
rjames
I replaced my fuel injectors on my 2.0 - 4 and th... Dec 12 2024, 02:53 PM
Vicioso
I replaced my fuel injectors on my 2.0 - 4 and t... Dec 13 2024, 11:11 AM
914Sixer Tell us about the replacement injectors, are they ... Dec 12 2024, 05:24 PM
Vicioso
Tell us about the replacement injectors, are they... Dec 13 2024, 11:36 AM
emerygt350 If you turn the key on and actuate the throttle yo... Dec 13 2024, 05:38 AM
rfinegan Does the fuel pump prime on key on or hear it whil... Dec 13 2024, 07:23 AM
fiacra This is such a common scenario... I did X and then... Dec 13 2024, 09:27 AM
FlacaProductions
And, just for fun, check the CHT connection....
... Dec 13 2024, 09:50 AM
Vicioso Yes I sprayed starter fluid and it ran great for a... Dec 13 2024, 11:15 AM
fiacra
Yes I sprayed starter fluid and it ran great for ... Dec 13 2024, 11:52 AM
Vicioso I just checked the box and yes they are Standard F... Dec 13 2024, 11:38 AM
Vicioso Just checked the CHT its fine and yes the car ran ... Dec 13 2024, 12:26 PM
Superhawk996
What does this re... Dec 13 2024, 12:42 PM
Vicioso Sorry I work on Motocross bikes way easier. yes I... Dec 13 2024, 04:05 PM
Superhawk996
Sorry I work on Motocross bikes way easier. …
... Dec 13 2024, 05:50 PM
Superhawk996 Also seeing you are new to the site :wttc: Dec 13 2024, 05:53 PM
Puebloswatcop :wttc: Don't give up. These cars can be very... Dec 14 2024, 09:08 AM
Vicioso I agree the car is fun and will be again once this... Dec 14 2024, 10:01 AM
914_teener I'm in Prescott. Let me know if you want my ey... Dec 15 2024, 03:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 11:18 PM |
