| Chad911sc |
Dec 11 2024, 04:46 PM
Member ![]() ![]() Group: Members Posts: 328 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
I have my short block built and I’m ready to set my deck height. It’s 96mm bore with stock 71mm factory crank. This is a 2.0 2056 build. I have a Web 86a cam calling for approx 9:1 compression. I have 60cc heads with 3cc valve reliefs on my flat top pistons. If I plug all this into the calculator, I get 8.3:1 for my compression ratio if I set the deck height to .040 inch
After I set up the piston on the rod and bolt down the cylinder to the block, I get .053 inch from the piston to the top of the cylinder. My question is, what is the best way to proceed to get the 9:1 ratio with at least .040 inch total deck height. I am thinking that if I take off 6 total cc’s from the head, that will leave me with 54cc heads with the 3cc valve pocket = total 57cc’s. Bringing me now to the correct 9:1 compression ratio with the .040 inch deck height. If I am in the right ballpark, this means I need to have my heads fly cut….correct?? If this is correct, how do I go about calculating how many thousands of an inch do I need to have removed by the machine shop to remove 6cc from the head? I obviously will need to remove at least .013 inch total deck height get to my .040 goal, and that’s with no shims or head gaskets being used. Thanks for your time, Chad |
| Jack Standz |
Dec 24 2024, 03:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 987 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Merry Christmas everyone!
Well, you'll figure out the next step when you measure everthing and do the mock-up. Fingers crossed that you're not too tight on the deck height. As technicalninja says, you don't want to be too close. Pistons hitting valves do tend to ruin one's day (IMG:style_emoticons/default/smile.gif) . But, sometimes we do tend to push the envelope. And sometimes the envelope pushes us. For a 2056, you don't need to cut it that close anyway and they are a fun motor in a 914. |
Chad911sc Setting deck height for 9:1 compression Dec 11 2024, 04:46 PM
Chad911sc I have my short block built and I’m ready to set... Dec 11 2024, 04:49 PM
technicalninja You're on the right track.
Altering the cylin... Dec 11 2024, 05:36 PM
930cabman top of then cylinders MUST be in plane with each o... Dec 11 2024, 06:24 PM
Shivers You need to raise the compression, right? If so yo... Dec 11 2024, 06:29 PM
cgnj Was your case decked?
Did you check the volume of ... Dec 12 2024, 12:14 AM
Chad911sc Thanks for the replies!
I did cc the heads and... Dec 12 2024, 09:38 AM
rfinegan Yes Get your deck hight sorted first...
Then set t... Dec 12 2024, 10:31 AM
technicalninja
I did cc the heads an... Dec 12 2024, 11:08 AM
930cabman
I did cc the heads a... Dec 12 2024, 01:27 PM
Chad911sc Very true!!
I actually watched all of Ianâ... Dec 12 2024, 02:05 PM
Chad911sc Spent the day on your recommendation to resurface ... Dec 14 2024, 02:10 PM
Jack Standz This should work fine for a shade tree mechanic re... Dec 14 2024, 03:13 PM
iankarr All great advice. Glad you found the videos helpfu... Dec 14 2024, 05:19 PM
Jack Standz I'd assume that your decks aren't flat, no... Dec 15 2024, 11:50 AM
Jack Standz One more thought.
Raby in this video says that g... Dec 15 2024, 12:19 PM
technicalninja :agree:
Jack is right!
Someone (maybe Jack ... Dec 15 2024, 02:33 PM
Chad911sc Thanks for all the replies!
Wish I would have ... Dec 16 2024, 02:39 PM
Superhawk996
They were both at .053 before the lapping and now... Dec 17 2024, 09:21 AM
seanpaulmc A guy local to me rebuilding his 912 built up a 22... Dec 17 2024, 07:50 AM
Chad911sc Awesome! Thanks Sean!
I’ve heard of Rev ... Dec 17 2024, 09:46 AM
seanpaulmc Okay, so where is the build thread? As you may no... Dec 17 2024, 06:52 PM
Chad911sc So I have the case halves back apart and now just ... Dec 18 2024, 01:17 PM
Chad911sc I think I figured it out with my daughters help…... Dec 18 2024, 01:32 PM
Chad911sc This is the 74 914 that it is going into…one of ... Dec 18 2024, 01:37 PM
Chad911sc Question….
When I get my heads fly cut, it looks... Dec 18 2024, 09:59 PM
technicalninja On a bone stock 73 2.0l the depression in the head... Dec 18 2024, 10:50 PM
Jack Standz
So I have the case halves back apart and now just... Dec 19 2024, 07:15 AM
Chad911sc I understand what you are saying about the deck pa... Dec 19 2024, 08:41 AM
technicalninja
I understand what you are saying about the deck p... Dec 19 2024, 10:37 AM
Jack Standz
I, personally, don't believe EVERYTHING Jake... Dec 19 2024, 12:15 PM
Chad911sc Thanks guys!
Now worries, no offense taken. Li... Dec 19 2024, 01:12 PM
rfinegan duplicated Dec 19 2024, 02:27 PM
rfinegan Am I missing something...
Machine the case to the ... Dec 19 2024, 02:33 PM
technicalninja The case line SHOULD be centered but...
Where it ... Dec 19 2024, 03:20 PM
rfinegan great follow up. Thanks for the information Dec 19 2024, 03:34 PM
technicalninja The 911 is COOL!
What's that white car in... Dec 19 2024, 04:26 PM
Jack Standz Chad,
Awesome looking 911SC. You should be worki... Dec 19 2024, 08:33 PM
Chad911sc The 911sc is actually a Max Moritz built Porsche. ... Dec 20 2024, 09:11 AM
technicalninja Let's see here...
500 hp Vette
Nice NICE NICE... Dec 20 2024, 01:26 PM
Chad911sc Trust me! That was my first thought when purch... Dec 23 2024, 10:45 AM
Chad911sc Talked to the machine shop today and they ended up... Dec 24 2024, 12:47 PM
technicalninja Will .010 give you the deck height you needed?
I ... Dec 24 2024, 01:02 PM
technicalninja I always check deck height of ALL of the pistons.
... Dec 24 2024, 03:41 PM
Chad911sc Merry Christmas Everyone!!
After I had han... Dec 25 2024, 09:35 AM
technicalninja
I... Dec 25 2024, 10:09 AM
sixnotfour OMG... Dec 25 2024, 03:24 PM
porschetub
OMG...
:agree: ,hopefully for the same reason ... Dec 25 2024, 08:29 PM
technicalninja
I have a disease…..
Project mania…lol
Love to... Dec 26 2024, 10:19 AM
emerygt350 No kidding. I think it would be fun to try and bu... Dec 26 2024, 03:37 PM
Chad911sc That 2110cc type 1 engine was built by Sid Collins... Dec 30 2024, 08:52 AM
technicalninja I did do a deep dive into turbo T4s after seeing y... Dec 30 2024, 09:47 AM
Chad911sc I do remember that my boost exhaust gate was set a... Dec 30 2024, 12:18 PM
technicalninja Chad, I wouldn't spec a "draw through... Dec 30 2024, 12:45 PM
Chad911sc Ok….
Everything is back together after the deck ... Jan 9 2025, 11:30 AM
technicalninja On a single bank the jugs have to be level with ea... Jan 9 2025, 11:55 AM
Chad911sc 10-4
That’s what I was hoping to hear…
In my p... Jan 9 2025, 12:41 PM
technicalninja I wouldn't worry about flawless balance on any... Jan 9 2025, 12:52 PM
Chad911sc Ok…sounds good!
I’ll leave it alone and mo... Jan 9 2025, 12:57 PM
technicalninja Important point!
Verify camshaft base circle ... Jan 9 2025, 01:03 PM
Chad911sc It is a new Web cam that is advertised as base cir... Jan 9 2025, 03:57 PM
technicalninja ALL camshafts should be "base circle concentr... Jan 9 2025, 04:29 PM
Chad911sc I’m off this weekend and will be back at it.
Can... Jan 9 2025, 07:19 PM
technicalninja Drop dead simple...
Set up dial indicator so it r... Jan 9 2025, 07:48 PM
technicalninja Just had a post from Jack Standz in my base circle... Jan 10 2025, 04:17 PM
GBX0073
Just had a post from Jack Standz in my base circl... Jan 18 2025, 01:13 PM
Chad911sc You can get those custom cut aluminum push rods fr... Jan 16 2025, 04:31 PM
zig-n-zag Type 4 rocker arms have different ratios for the i... Jan 17 2025, 09:19 PM
rfinegan let us know...
CB has a set that look tempting
ht... Jan 18 2025, 06:19 PM
rfinegan or this one...
https://www.cbperformance.com/produ... Jan 18 2025, 06:20 PM
GBX0073 Rob
Great Find your always a great reference for ... Jan 19 2025, 12:29 AM
Chad911sc Stateside tuning has these available now. It only ... Jan 23 2025, 04:17 PM
Chad911sc Thanks Zigzag!!!
I feel better now tha... Jan 23 2025, 04:21 PM
Chad911sc I ended up taking .002 off the top of the piston t... Jan 23 2025, 04:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 11:42 AM |
