| jim_hoyland |
Dec 26 2024, 04:52 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,041 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
There are 4 Allen Head bolts holding the steering column to the frame above.
I need to loosen those bolts to lower steering column an inch; reason is the tach in my Getty dash won’t clear the steering column shroud. So, I’m attempting to lower the column to get room so the tach can be pulled out. But, the Allen head bolts are really tight; no arm strength was going to budge them. And, I don’t want to ruin the Allen bolt heads What is the solution to loosening those bolts ? |
| SirAndy |
Dec 26 2024, 05:08 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You don't need to lower the steering column.
You can simply remove the screws holding the face-plate to the Getty dash. I think there are 8? 6 on the face and 2 on the bottom? Don't remember exactly. Once those are out, you can angle the face-plate and remove any of the gauges. It helps to remove the steering wheel though to give you more room. (IMG:style_emoticons/default/shades.gif) |
jim_hoyland Steering Column Bolts Dec 26 2024, 04:52 PM
JeffBowlsby A bigger lever arm on that Allen wrench. Maybe so... Dec 26 2024, 04:54 PM
windforfun It's time for a pipe. And not the kind you sm... Dec 26 2024, 05:14 PM
technicalninja :agree:
SirAndy has the correct answer!
But... Dec 26 2024, 05:18 PM
sixnotfour Hope you get a solution.. saw your message late l... Dec 26 2024, 06:13 PM
jim_hoyland thanks; that gives some new ideas,
I have the soc... Dec 26 2024, 06:58 PM
Root_Werks Careful with the impact tool. Maybe try the rachet... Dec 26 2024, 07:04 PM
jim_hoyland
Careful with the impact tool. Maybe try the rache... Dec 26 2024, 07:27 PM
Root_Werks Yikes, those are really in there. Welp, impact it... Dec 27 2024, 12:48 PM
technicalninja If I can get to the threaded section, I'll hos... Dec 27 2024, 01:05 PM
rfinegan A hand impact/ hammer with Allen socket and the sh... Dec 27 2024, 02:37 PM
jim_hoyland
A hand impact/ hammer with Allen socket and the s... Dec 27 2024, 05:49 PM
jim_hoyland Update: Had to use a cheater them to loosen. Six c... Mar 7 2025, 05:13 PM
sixnotfour :trophy: :driving: Mar 7 2025, 08:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:37 AM |
