captjm |
Newbie ![]() Group: Members Posts: 16 Joined: 28-January 07 From: Temecula, CA Member No.: 7,485 ![]() |
There is a two bolt bracket that secures the steering gear shaft "steering bearing and rubber boot". How tight should these bolts be? The bolts are M8 x1.25 x15 mm socket head. I did not find a torque setting anywhere and securing them too tight might just damage the rubber? Any thoughts?
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,199 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Good n’ tight is standard German torque when in doubt. (IMG:style_emoticons/default/av-943.gif)
The metal clamp goes metal to metal with the chassis below it. It is designed to put minimal compression on the needle bearing / rubber that it is holding. Standard MAXIMUM torque for an M8 grade 8 fastener is around 30 Nm (22 lb-ft). 70% of this value is about right for this situation. Let’s call it 15 lb-ft or there abouts. Otherwise look up the specific torque for Allen Head fastener (usually grade 10.9 or 12.9). That value is going to be much higher than what is actually needed here. |
captjm |
Good n’ tight is standard German torque when in doubt. (IMG:style_emoticons/default/av-943.gif) The metal clamp goes metal to metal with the chassis below it. It is designed to put minimal compression on the needle bearing / rubber that it is holding. Standard MAXIMUM torque for an M8 grade 8 fastener is around 30 Nm (22 lb-ft). 70% of this value is about right for this situation. Let’s call it 15 lb-ft or there abouts. Otherwise look up the specific torque for Allen Head fastener (usually grade 10.9 or 12.9). That value is going to be much higher than what is actually needed here. Thank you and to all that responded ! I have a plan now and can finish this compartment. |
Lo-Fi Version | Time is now: 4th July 2025 - 09:05 AM |
