> Rear Shock Assembly for 914-6 - Boge
DennisV
post Dec 30 2024, 07:28 PM
I hate to belabor the rear shock topic, but I am stuck. I didn't have the original setup to reference, and I'm not finding much in terms of Boge details for 914-6.
  • #6 Bump stop: Taper up or down? In the drawings and videos I’ve seen, it goes down. When I trial assemble, it seats much better into #8 cap when taper goes up.
  • #5 Rubber stop washer: Does the side with grooves go up or down?
  • #4 Cap - boge: Does the beveled side (i.e., smaller OD side) go up or down? Why does it even have a bevel?
  • #4 Cap - boge: I assume it is meant to rest on the beveled edge of the strut shaft? When I trial assemble (without the spring) I doesn’t seem like there is enough length to get the #10 threaded bushing to start without some serious compression on #6 bump stop. Is this correct?
  • #17 Washer: What is OD and thickness?
Thanks for any assistance.
Superhawk996
post Dec 30 2024, 09:26 PM
That is totally wrong but the PET diagram is garbage as far as an exploded diagram goes so that no slam on you.
Washer #5 should have a hole large enough to allow it to slide to the bottom of the damper rod. It goes at the bottom and should basically be resting on the damper body. This is the first thing to go on the damper. The purpose of the slots is to prevent a vacuum from getting formed on the damper seal (inside damper body) when the jounce bumper gets squished under hard compression.
The yellow bounce bumper #6 should have a hole large enough to slide all the way to the bottom of the damper rod.
The washer #4 that you have at the top of the damper rod has a smaller hole - supposed to stay at the top of the damper rod. However it nests into the top spring retainer/perch #8 on PET. You’ll note it is stepped - this will allow it to “nest” into the spring retainer. Smaller stepped side to the top.
DennisV
post Dec 31 2024, 08:16 PM
QUOTE(Superhawk996 @ Dec 30 2024, 07:26 PM) *
Thank you very much for taking time to post this. I think I have it sorted now.
You are correct that I was using the parts catalog as an exploded diagram, which I guess I should not. It was definitely confusing in this case.
The yellow bounce bumper #6 went on all the way down, but required some dish soap and persuasion.
DennisV   Rear Shock Assembly for 914-6 - Boge   Dec 30 2024, 07:28 PM
Superhawk996   That is totally wrong but the PET diagram is garba...   Dec 30 2024, 09:26 PM
DennisV   That is totally wrong but the PET diagram is garb...   Dec 31 2024, 08:16 PM
davep   You are correct that I was using the parts catalo...   Dec 31 2024, 10:09 PM
DennisV   #6 bumper will ride up the shaft as the spring ge...   Jan 1 2025, 07:25 AM
davep   I thought the washer with the curved lip top left...   Jan 1 2025, 06:54 PM
Superhawk996   The jounce bumper doesn’t contact anything until...   Dec 30 2024, 09:34 PM
Superhawk996   Here’s a couple other pictures of rear dampers a...   Dec 30 2024, 10:26 PM
davep   Here’s a couple other pictures of rear dampers ...   Dec 31 2024, 09:58 PM
Superhawk996   The original bump stop had the stepped washer bo...   Jan 1 2025, 01:48 AM
Superhawk996   :trophy:   Dec 31 2024, 08:27 PM
davep   The PET diagram is not too bad if you look at the ...   Dec 31 2024, 09:49 PM
DennisV   4 dust cap (stamped metal fits over the shock bod...   Jan 1 2025, 07:15 AM
Cairo94507   An excellent thread on rear shock assembly. Now I...   Jan 1 2025, 08:06 AM
Superhawk996   Was trying to find a NOS rear jounce bumper to see...   Jan 1 2025, 01:29 PM
StarBear   Was trying to find a NOS rear jounce bumper to se...   Apr 26 2026, 05:15 PM
Superhawk996   @DennisV The jounce bumpers you already have wi...   Jan 1 2025, 02:25 PM
Superhawk996   I guess while I’m :deadhorse: I might as well...   Jan 1 2025, 02:33 PM
davep   I had a dozen of the orange bump stops, but the fo...   Jan 1 2025, 07:44 PM
DennisV   Most of my parts are buried at this time, but if ...   Jan 2 2025, 02:20 PM
Artfrombama   I had a dozen of the orange bump stops, but the f...   Jan 18 2025, 01:19 AM
StarBear   I had a dozen of the orange bump stops, but the ...   Apr 26 2026, 05:16 PM
rgalla9146   Great thread. My reply is a bit off topic...bea...   Jan 2 2025, 03:11 PM
DennisV   Rear Boges grey ? ...don't remember. ...   Jan 2 2025, 03:41 PM
DennisV   For anyone researching this in the future, I have ...   Jan 3 2025, 12:14 PM
Cairo94507   :trophy: Thanks for doing that. :beer2: Michael   Jan 3 2025, 12:39 PM
DennisV   [b]TL;DR It doesn't appear #4 is needed as a s...   Jan 17 2025, 05:02 PM
- Lo-Fi Version Time is now: 27th April 2026 - 05:45 AM
