| friethmiller |
Dec 31 2024, 12:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
[A softball question for the Ninja and/or others]
This is the cam card that came with my 2357 engine, which was originally built by Rimco/Fat (long block) a few years ago. Can someone explain why with an intake/exhaust of 448, the lift was only set to 327 degrees? I'm about to rebuild my motor and a lot of focus will be directed at piston "deck clearance" and the valve train geometry that wasn't set correctly. Thanks. ![]() |
| technicalninja |
Jan 1 2025, 10:28 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Reality check...
I never said anything because it was not my place, you seemed very enthusiastic and a super nice guy... Your engine SUCKED DONKEY BALLS! If you remember the point at which I was driving the car... Did I ever say, "Oh this is bad-assed"! I remember thinking "NFW I'd have spent big bucks on this level of performance". It "felt" like maybe 130hp, 100 at the wheels... I was NOT impressed! The cam, the build quality, the tuning was way off! Makes sense now. Thanks for the pictures! You're NOT going to like what I see... If this is a 6k mile motor, you got screwed. Your bearings look a SHITLOAD worse than the bearings I pulled out of a "dead" core 2.0L I bought from 914sixer. Your cam shit is trashed. The cam bearings show mis-alignment too! The level of deposits on the head and piston crown looks BOTH too rich/un-tuned AND bad oil consumption... Bores don't look great either. That critter WOULD get the line bore checked/done. Registers milled. Crank micro polished (minimum) or turned. The most forward (towards belt) rod journal on the crank looks like it might require machine work. I didn't notice any evidence of balancing on that crank (weird small drill marks that don't look factory.) These look like someone was starting a hole. It's normal to have more than one and the holes are almost always at differing depths. The last one usually just barely marks the surface. Don't see of that at all! The flywheel is "juicier" than it should be at 6K. Leaking from flywheel bolts (you can see the streaks). No "Raby" RMS mods. This is "low hanging fruit' and should be done on ANY rebuild, even cheap ass ones, as it costs nothing... If you want, you're welcome to bring that stuff up to my shop and I'll do a HARSH inspection while you're looking on. I'd have had those valves out of the heads early... And the saddest point of all... I can assess customers freaking fast! In just a few minutes I can tell if the customer is price sensitive and how much trouble I'm going to have with them. This comes from 40 years of dealing with differing levels of customers. You're NOT a cheapskate! After properly explaining why I'd EXPECT you to take the "more correct route" over the "more economical route" (there are ALWAYS at least two ways to skin the cat). You have money too! Maybe not shitloads but more than enough to properly build a T4. And you got taken advantage of... Ninja sad, sympathetic with customer... (IMG:style_emoticons/default/ninja.gif) |
| friethmiller |
Jan 1 2025, 11:06 AM
Reality check... I never said anything because it was not my place, you seemed very enthusiastic and a super nice guy... Your engine SUCKED DONKEY BALLS! If you remember the point at which I was driving the car... Did I ever say, "Oh this is bad-assed"! I remember thinking "NFW I'd have spent big bucks on this level of performance". It "felt" like maybe 130hp, 100 at the wheels... I was NOT impressed! The cam, the build quality, the tuning was way off! Makes sense now. Thanks for the pictures! You're NOT going to like what I see... If this is a 6k mile motor, you got screwed. Your bearings look a SHITLOAD worse than the bearings I pulled out of a "dead" core 2.0L I bought from 914sixer. Your cam shit is trashed. The cam bearings show mis-alignment too! The level of deposits on the head and piston crown looks BOTH too rich/un-tuned AND bad oil consumption... Bores don't look great either. That critter WOULD get the line bore checked/done. Registers milled. Crank micro polished (minimum) or turned. The most forward (towards belt) rod journal on the crank looks like it might require machine work. I didn't notice any evidence of balancing on that crank (weird small drill marks that don't look factory.) These look like someone was starting a hole. It's normal to have more than one and the holes are almost always at differing depths. The last one usually just barely marks the surface. Don't see of that at all! The flywheel is "juicier" than it should be at 6K. Leaking from flywheel bolts (you can see the streaks). No "Raby" RMS mods. This is "low hanging fruit' and should be done on ANY rebuild, even cheap ass ones, as it costs nothing... If you want, you're welcome to bring that stuff up to my shop and I'll do a HARSH inspection while you're looking on. I'd have had those valves out of the heads early... And the saddest point of all... I can assess customers freaking fast! In just a few minutes I can tell if the customer is price sensitive and how much trouble I'm going to have with them. This comes from 40 years of dealing with differing levels of customers. You're NOT a cheapskate! After properly explaining why I'd EXPECT you to take the "more correct route" over the "more economical route" (there are ALWAYS at least two ways to skin the cat). You have money too! Maybe not shitloads but more than enough to properly build a T4. And you got taken advantage of... Ninja sad, sympathetic with customer... (IMG:style_emoticons/default/ninja.gif) (IMG:style_emoticons/default/agree.gif) I appreciate your honesty, Rick! I don't need my sh1t sugar-coated. I was never happy with the performance of this build. either. Question is, what's the path forward? There's not a lot of bearing options with a crank that is already -.10 on the mains and -.20 on the rod journals, I don't think. Perhaps a new crank (at whatever size) that will take STD bearings, new cam setup (lifters/pushrods), and new 96mm jugs. (IMG:style_emoticons/default/idea.gif) Regardless, the case is going to a trusted shop that will inspect/machine, if necessary. Just need to find that place. |
friethmiller Fred's 2375 Rebuild Thread Dec 31 2024, 12:12 PM
technicalninja It's probably showing actual lift of the lobe.... Dec 31 2024, 12:31 PM
friethmiller
It's probably showing actual lift of the lobe... Dec 31 2024, 12:45 PM
technicalninja looking again that whole cam card is at .050!
... Dec 31 2024, 12:50 PM
friethmiller
looking again that whole cam card is at .050... Dec 31 2024, 01:09 PM
technicalninja I'd have to see the cam card on it.
I'd l... Dec 31 2024, 01:38 PM
technicalninja Changing cam in a T4 means "all the way down... Dec 31 2024, 02:13 PM
friethmiller Ok, I've changed to name of this thread to han... Dec 31 2024, 02:50 PM
technicalninja WOW!
Was that engine in the car the time you ... Dec 31 2024, 03:28 PM
technicalninja Pics please!
Clean and label all of the split... Dec 31 2024, 03:39 PM
friethmiller
Pics please!
Clean and label all of the spli... Dec 31 2024, 04:44 PM
friethmiller Engine pics
Tear down:
... Dec 31 2024, 05:39 PM
friethmiller More Pics
Camshaft:
[u]Camshaft Bearings:
... Dec 31 2024, 07:06 PM
friethmiller More Pics:
Note: any perpendicular marks are from... Dec 31 2024, 07:23 PM
friethmiller Crankshaft Journal Measurements:
Note: main jour... Dec 31 2024, 07:51 PM
technicalninja Are the pistons true flat tops with no valve depre... Jan 1 2025, 11:08 AM
friethmiller
Are the pistons true flat tops with no valve depr... Jan 1 2025, 11:19 AM
technicalninja I MAY have a close machine shop.
Replacing everyt... Jan 1 2025, 11:28 AM
friethmiller Web Cam has a 494 grind with a 1” base circle me... Jan 1 2025, 02:08 PM
technicalninja Those might not be JE pistons!
I have 2 new s... Jan 1 2025, 02:24 PM
technicalninja Looked at that cam. That wouldn't be my first ... Jan 1 2025, 02:47 PM
friethmiller Interesting, I'll take a look here in a bit. ... Jan 1 2025, 03:25 PM
technicalninja Flat top 96mm 82 stroke. 593.53 CC swept volume. T... Jan 1 2025, 03:42 PM
technicalninja Those ARE Keith Black "silverlines".
Tha... Jan 1 2025, 04:03 PM
friethmiller
Th... Jan 1 2025, 05:56 PM
technicalninja I noticed it almost looks like those have a solid ... Jan 1 2025, 04:14 PM
Jack Standz Just some thoughts and first impressions.
Thos... Jan 1 2025, 04:56 PM
friethmiller
Tho... Jan 1 2025, 06:08 PM
Jack Standz Since you're rebuilding the motor, let me sup... Jan 1 2025, 05:20 PM
friethmiller 9.7:1 Compression Ratio. Damn! That is hot... Jan 1 2025, 06:20 PM
technicalninja Intake and exhaust are fine, should support deep i... Jan 1 2025, 07:25 PM
technicalninja The pinning is not a big deal.
Needs to be done o... Jan 1 2025, 07:33 PM
friethmiller Going to cc the heads first. I measured the ID of... Jan 2 2025, 08:56 AM
technicalninja The above looks good.
Easier to see the bubbles i... Jan 2 2025, 09:23 AM
technicalninja These might help.
https://www.amazon.com/ABN-Cyli... Jan 2 2025, 09:26 AM
friethmiller
These might help.
https://www.amazon.com/ABN-Cyl... Jan 2 2025, 09:44 AM
Jack Standz If/when you get around to ceracoating things, as t... Jan 2 2025, 09:29 AM
friethmiller
If/when you get around to ceracoating things, as ... Jan 2 2025, 09:46 AM
technicalninja
If/when you get around to ceracoating things, as... Jan 2 2025, 09:55 AM
VaccaRabite I've got some opinions here.
Remember that ... Jan 2 2025, 10:09 AM
friethmiller
Zach
Z... Jan 2 2025, 11:21 AM
technicalninja
Remember that... Jan 2 2025, 01:49 PM
cgnj Falcor75 2270 made 158 to the wheels with 10:1, 86... Jan 2 2025, 02:24 PM
friethmiller
Falcor75 2270 made 158 to the wheels with 10:1, 8... Jan 2 2025, 03:16 PM
friethmiller Ok, Cylinder test via antifreeze titration says 60... Jan 2 2025, 03:22 PM
friethmiller @technicalninja - Initial look at deck height her... Jan 2 2025, 09:14 PM
friethmiller BTW. I’ll put the head stud back and tighten it... Jan 2 2025, 09:57 PM
technicalninja Normal quench, .040"thick,96mm bore is 7.2 cc... Jan 2 2025, 10:10 PM
friethmiller
Did FAT supply those pistons?
Yes, crank, cam, ... Jan 2 2025, 10:19 PM
technicalninja I don't remember what gauges you had...
Minim... Jan 2 2025, 10:32 PM
Jack Standz VaccaRabite made several good points about the CR.... Jan 3 2025, 12:17 AM
friethmiller Thanks guys! My head is starting to spin here... Jan 3 2025, 08:56 AM
technicalninja I'd go option 1.
JE does offer coatings done ... Jan 3 2025, 09:17 AM
technicalninja I'd want the cam and its stuff to map out valv... Jan 3 2025, 09:32 AM
friethmiller
Did you verify total stroke?
Need to compare CD... Jan 3 2025, 09:56 AM
technicalninja Yep, how far down +/- deck height.
Dial caliper w... Jan 3 2025, 10:14 AM
technicalninja At this "level" of engine I'd expect... Jan 3 2025, 10:23 AM
friethmiller
At this "level" of engine I'd expec... Jan 3 2025, 10:32 AM
friethmiller Ok :ninja: , I used the two shims under the #1 jug... Jan 3 2025, 11:02 AM
friethmiller Ok, my 1.7L rocker arms do NOT have elephant feet.... Jan 3 2025, 11:26 AM
technicalninja https://aapistons.com/collections/porsche-p...ston... Jan 3 2025, 11:45 AM
friethmiller
https://aapistons.com/collections/porsche-p...sto... Jan 3 2025, 12:05 PM
cgnj @[url=http://www.914world.com/bbs2/index.php?showu... Jan 3 2025, 12:59 PM
friethmiller
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jan 3 2025, 01:19 PM
densible1 I had EMS http://www.europeanmotorworks.com do the... Jan 3 2025, 01:31 PM
technicalninja Check with Eric @ Automotive Machine.
https://www... Jan 3 2025, 02:48 PM
technicalninja And, if I could, I'd pattern the cam I chose o... Jan 3 2025, 02:56 PM
friethmiller Thanks Rick,
I'll take my case and crank (+ ... Jan 3 2025, 03:17 PM
burton73 @ friethmiller
I just spent a bit of time with Ma... Jan 3 2025, 03:30 PM
densible1 @[url=http://www.914world.com/bbs2/index.php?showu... Jan 3 2025, 04:09 PM
friethmiller
@[url=http://www.914world.com/bbs2/index.php?show... Jan 4 2025, 07:40 AM
burton73
[quote name='densible1' post='3184740' date='Jan ... Jan 4 2025, 02:07 PM
Montreal914 I am very far from being an expert but I did a lot... Jan 3 2025, 04:09 PM
friethmiller
I am very far from being an expert but I did a lo... Jan 3 2025, 11:11 PM
technicalninja That RAT engine used those same KBs and a big cam.... Jan 3 2025, 05:58 PM
cgnj @Montreal914 [b]@[url=http://www.914world.com/bb... Jan 3 2025, 06:55 PM
friethmiller
I have 3 cases that I'm going to drop off soo... Jan 4 2025, 05:51 AM
technicalninja It would be useful to have the shim measurements.
... Jan 3 2025, 09:10 PM
friethmiller
It would be useful to have the shim measurements.... Jan 3 2025, 10:25 PM
Montreal914 2270 = 78.4 x 96mm
2258 = 78 x 96mm
78.4 cranks w... Jan 4 2025, 09:16 AM
cgnj Since we are all spending your money, oil spray gr... Jan 4 2025, 11:19 AM
friethmiller
Since we are all spending your money, oil spray g... Jan 6 2025, 01:59 PM
technicalninja
[quote name='technicalninja' post='3184830' date=... Jan 4 2025, 11:32 AM
technicalninja I would LOVE to know why the pics don't post o... Jan 4 2025, 02:55 PM
Superhawk996 100mm
Jan 4 2025, 03:37 PM
technicalninja At this level of build I would be hunting thermal ... Jan 4 2025, 03:45 PM
technicalninja Thanks SH!
Look at how thick the walls are. T... Jan 4 2025, 04:01 PM
technicalninja Need P-W clearance. If they "sized for forged... Jan 4 2025, 04:24 PM
friethmiller Just got back in from welding on the front cross p... Jan 4 2025, 04:42 PM
technicalninja and yet another thought...
I slipped a set of sto... Jan 4 2025, 05:05 PM
friethmiller :ninja: Used a digital micrometer on all piston sk... Jan 4 2025, 08:18 PM
technicalninja You need to be halfway down the skirt, below the p... Jan 4 2025, 08:32 PM
friethmiller
You need to be halfway down the skirt, below the ... Jan 4 2025, 09:13 PM
technicalninja That range is GREAT!
It almost looks like a .... Jan 5 2025, 12:04 AM
technicalninja You have accurate tools.
You measured close to .... Jan 5 2025, 12:25 AM
friethmiller
You measured close to ... Jan 5 2025, 10:20 AM
technicalninja It's both the sight and the feel in tenths...
... Jan 5 2025, 01:43 PM
technicalninja
:ninja: Used a digital micrometer on all piston s... Jan 5 2025, 03:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th September 2026 - 04:28 AM |
