> Push rol tube removal, Is there a tool to pull them??
PaIsa
post Jan 1 2025, 09:25 AM
So I tried to replace the o-rings on the push rod tubes. I was able to pull 3 out of the 8 tubes using pliers but I cannot believe that there is not an easier and more efficient way of pulling those tube out. Not saying that using pliers, even when being careful, there is a risk of damaging the tube.
Does anyone know of a tool to get them out? I would see some kind of expanding device that fits inside of the tube with a kind of slide hammering device to get them out. I am pretty sure that someone that does this routinely will have a tool!
Aerostatwv
post Jan 1 2025, 11:33 AM
I crack them loose with a pair of vice grips by twisting first to break the friction and then slide them out. You can put a rag around the tube so as not to mar the finish, but has never been an issue for me.
PaIsa   Push rol tube removal   Jan 1 2025, 09:25 AM
rfinegan   I have had pretty good luck wrapping a shop rag ar...   Jan 1 2025, 10:05 AM
PaIsa   I have had pretty good luck wrapping a shop rag a...   Jan 2 2025, 10:05 AM
technicalninja   Get them to rotate first, I use lots of WD/40 here...   Jan 1 2025, 10:36 AM
GregAmy   Not helpful to your immediate problem, but I'm...   Jan 1 2025, 11:08 AM
930cabman   Not helpful to your immediate problem, but I...   Jan 1 2025, 03:43 PM
Aerostatwv   I crack them loose with a pair of vice grips by tw...   Jan 1 2025, 11:33 AM
Jack Standz   What everyone else said and have had good luck wit...   Jan 1 2025, 03:31 PM
cgnj   Hose pilers are your friend.   Jan 2 2025, 10:51 AM
porschetub   Hose pilers are your friend. :agree: that's...   Jan 3 2025, 07:53 PM
PaIsa   Hose pilers are your friend. Pliers were the to...   Jan 3 2025, 09:31 PM
brant   Hose pilers are your friend. Pliers were the t...   Jan 4 2025, 09:33 AM
KELTY360   [quote name='PaIsa' post='3184834' date='Jan 3 20...   Jan 4 2025, 10:47 AM
Montreal914   Before reinstalling them with the proper viton O-r...   Jan 4 2025, 09:27 AM
76-914   Strap Wrench!   Jan 4 2025, 09:29 AM
technicalninja   :agree: :agree: :agree: I grease the crap out ...   Jan 4 2025, 12:51 PM
emerygt350   I have had pretty good luck beating them back into...   Jan 4 2025, 08:23 PM
PaIsa   I will probably get back at it this week end with ...   Jan 6 2025, 06:15 AM
cgnj   It is difficult to fit pliers or vice grips betwee...   Jan 6 2025, 06:22 AM
PaIsa   Just to close this, I finally ended up buying a se...   Feb 13 2025, 12:34 PM
rjames   The one and only time I replaced a push rod tube I...   Feb 13 2025, 06:25 PM
- Lo-Fi Version Time is now: 1st April 2026 - 06:46 PM
