| DennisV |
Oct 22 2024, 07:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
While addressing a couple rust areas, I ran into a hard white substance that was painted over body color. It appears to be squirted or brushed on pretty thick. It wasn't applied with much care. I was able to chip, wire brush, or sand it out. I'm curious:
This is surrounding the heater vent tubes in the engine compartment. ![]() This is covering a half-circle cut-out in the driver floorboard just ahead of the pedals. ![]() I'm guessing the same stuff was used in the rear trunk over the screws holding the muffler shield bracket. |
| 930cabman |
Jan 3 2025, 12:56 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,572 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
NAPA has a decent "brushable" product. A spray on will give you a closer to factory look
DennisV Factory Caulk or Sealer Oct 22 2024, 07:38 PM
mepstein Seam sealer. Used all over the car. Lots of modern... Oct 22 2024, 07:51 PM
Superhawk996
There is a brushable version too. Both sprayed ... Oct 22 2024, 07:55 PM
DennisV
There is a brushable version too. Both sprayed a... Oct 23 2024, 01:17 PM
Zeke There is a good polyurethane strictly for the seam... Oct 22 2024, 10:57 PM
mepstein It is flexible but so is paint. Think about how al... Oct 23 2024, 01:57 PM
Superhawk996 Factory painted over it. Designed to be painted o... Oct 23 2024, 05:57 PM
nivekdodge it says for primed and unprimed but i would surely... Oct 23 2024, 06:10 PM
DennisV Here is what the Wurth Brushable Seam Sealer looks... Jan 3 2025, 12:37 PM
technicalninja
Factory painted over it. Designed to be painted ... Jan 3 2025, 12:59 PM
Superhawk996
Now, seam sealing a temporary job that you INTEN... Jan 3 2025, 04:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:43 AM |
