| DennisV |
Oct 22 2024, 07:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
While addressing a couple rust areas, I ran into a hard white substance that was painted over body color. It appears to be squirted or brushed on pretty thick. It wasn't applied with much care. I was able to chip, wire brush, or sand it out. I'm curious:
This is surrounding the heater vent tubes in the engine compartment. ![]() This is covering a half-circle cut-out in the driver floorboard just ahead of the pedals. ![]() I'm guessing the same stuff was used in the rear trunk over the screws holding the muffler shield bracket. |
| technicalninja |
Jan 3 2025, 12:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Factory painted over it. Designed to be painted over. No issues at all. Don’t judge me on the hillbilly AC holes patch job. I have the proper Restoration Design panel but needed these gaping holes filled in short term for a cross country move. Didn’t have time to do it to my satisfaction. (IMG:style_emoticons/default/hissyfit.gif) Ha! That's impressive! His "half/ass hillbilly" job is one of the better repaired frunk floors I've seen... That looks "permanent finished" to me! It's NOT concours but that is nice! Now, seam sealing a temporary job that you INTEND to replace is a bit on the "Mental" side of things... (IMG:style_emoticons/default/ninja.gif) |
| Superhawk996 |
Jan 3 2025, 04:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Now, seam sealing a temporary job that you INTEND to replace is a bit on the "Mental" side of things... (IMG:style_emoticons/default/ninja.gif) Had to be seam sealed to withstand the rainstorms it went through going cross country. Now painting it that was certainly mental (IMG:style_emoticons/default/happy11.gif) |
DennisV Factory Caulk or Sealer Oct 22 2024, 07:38 PM
mepstein Seam sealer. Used all over the car. Lots of modern... Oct 22 2024, 07:51 PM
Superhawk996
There is a brushable version too. Both sprayed ... Oct 22 2024, 07:55 PM
DennisV
There is a brushable version too. Both sprayed a... Oct 23 2024, 01:17 PM
Zeke There is a good polyurethane strictly for the seam... Oct 22 2024, 10:57 PM
mepstein It is flexible but so is paint. Think about how al... Oct 23 2024, 01:57 PM
Superhawk996 Factory painted over it. Designed to be painted o... Oct 23 2024, 05:57 PM
nivekdodge it says for primed and unprimed but i would surely... Oct 23 2024, 06:10 PM
DennisV Here is what the Wurth Brushable Seam Sealer looks... Jan 3 2025, 12:37 PM
930cabman NAPA has a decent "brushable" product. A... Jan 3 2025, 12:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:16 AM |
