> CCA Requirements?
Literati914
post Jan 4 2025, 12:09 AM
I'll be picking up a flooded cell lead acid battery soon (budget oriented battery for a rear trunk relocation) and have been leaning towards a group 51R battery. I like this size because they are small - think Mazda Miata, small Honda Civics, Nissan GT-R, IIRC. However, I think the original group 34 had around 700 CCA [is that correct?] and the 51R tends to have a little less (425-/+). The first engine will be a 1.7, but then I'll probably upgrade fairly quickly, possibly before the typical battery dies.
I sort of recall the CCA demand being dependent on the needs of the starter.. or something like that. Anyone know for sure what our starters require, amp wise? And/Or Will the 425 CCA work?
Superhawk996
post Jan 4 2025, 11:21 AM
Typical starter draw is about 100-200A under load but you also want “reserve” since battery state of charge is rarely 100% after sitting for a while or when cold.
Literati914   CCA Requirements?   Jan 4 2025, 12:09 AM
Superhawk996   Typical starter draw is about 100-200A under load ...   Jan 4 2025, 11:21 AM
technicalninja   51r will work fine (have to have good grounds/feed...   Jan 4 2025, 12:16 PM
fixer34   51r will work fine (have to have good grounds/fee...   Jan 4 2025, 02:30 PM
mepstein   [quote name='technicalninja' post='3184926' date=...   Jan 4 2025, 02:39 PM
Superhawk996   Speaking of small batteries, I would like someon...   Jan 4 2025, 03:04 PM
mlindner   Optima in the trunk but not small. Mark   Jan 4 2025, 12:51 PM
technicalninja   Speaking of small batteries, I would like someo...   Jan 4 2025, 03:21 PM
GregAmy   I am using this: https://www.batterywarehouseonlin...   Jan 4 2025, 06:03 PM
Literati914   51r will work fine (have to have good grounds/fee...   Jan 5 2025, 12:02 PM
Superhawk996   AGM without a doubt. Can mount in any orientati...   Jan 5 2025, 12:16 PM
mepstein   AGM without a doubt. Can mount in any orientat...   Jan 5 2025, 12:27 PM
porschetub   AGM without a doubt. Can mount in any orientat...   Jan 5 2025, 03:31 PM
zoomCat   Will the 425 CCA work? The factory battery was a...   Jan 5 2025, 01:00 PM
technicalninja   I'm a HUGE believer in gear reduction drive st...   Jan 5 2025, 03:53 PM
porschetub   I'm a HUGE believer in gear reduction drive s...   Jan 6 2025, 04:17 PM
scallyk9   I've got Interstate AGM Group 5 batteries from...   Jan 5 2025, 07:25 PM
Literati914   Great info, thanks everyone! I'm probably ...   Jan 5 2025, 11:19 PM
technicalninja   And here's a sign of the times... I had to pu...   Jan 8 2025, 02:04 PM
- Lo-Fi Version Time is now: 1st April 2026 - 08:16 PM
