| Literati914 |
Jan 4 2025, 12:09 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,235 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'll be picking up a flooded cell lead acid battery soon (budget oriented battery for a rear trunk relocation) and have been leaning towards a group 51R battery. I like this size because they are small - think Mazda Miata, small Honda Civics, Nissan GT-R, IIRC. However, I think the original group 34 had around 700 CCA [is that correct?] and the 51R tends to have a little less (425-/+). The first engine will be a 1.7, but then I'll probably upgrade fairly quickly, possibly before the typical battery dies.
I sort of recall the CCA demand being dependent on the needs of the starter.. or something like that. Anyone know for sure what our starters require, amp wise? And/Or Will the 425 CCA work? |
| technicalninja |
Jan 4 2025, 12:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
51r will work fine (have to have good grounds/feed wiring)
I'd go AGM even in the trunk. Walmart has what I'd buy https://www.walmart.com/ip/EverStart-Platin...130452206?gQT=2 $180 and you can put it anywhere! The stock location isn't bad... Lots of the Miata crowd goes TINY batteries. Like 5lbs. batteries! They seem to work pretty good too... |
| fixer34 |
Jan 4 2025, 02:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,405 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
51r will work fine (have to have good grounds/feed wiring) I'd go AGM even in the trunk. Walmart has what I'd buy https://www.walmart.com/ip/EverStart-Platin...130452206?gQT=2 $180 and you can put it anywhere! The stock location isn't bad... Lots of the Miata crowd goes TINY batteries. Like 5lbs. batteries! They seem to work pretty good too... Speaking of small batteries, I would like someone to explain how these lithium based 'jump start' kits with a battery the size of cigarette pack will start a car. |
Literati914 CCA Requirements? Jan 4 2025, 12:09 AM
Superhawk996 Typical starter draw is about 100-200A under load ... Jan 4 2025, 11:21 AM
[quote name='technicalninja' post='3184926' date=... Jan 4 2025, 02:39 PM
Superhawk996
Speaking of small batteries, I would like someon... Jan 4 2025, 03:04 PM
mlindner Optima in the trunk but not small. Mark Jan 4 2025, 12:51 PM
technicalninja
Speaking of small batteries, I would like someo... Jan 4 2025, 03:21 PM
GregAmy I am using this:
https://www.batterywarehouseonlin... Jan 4 2025, 06:03 PM
Literati914
51r will work fine (have to have good grounds/fee... Jan 5 2025, 12:02 PM
Superhawk996 AGM without a doubt.
Can mount in any orientati... Jan 5 2025, 12:16 PM
Can mount in any orientat... Jan 5 2025, 12:27 PM
porschetub
Can mount in any orientat... Jan 5 2025, 03:31 PM
zoomCat
The factory battery was a... Jan 5 2025, 01:00 PM
technicalninja I'm a HUGE believer in gear reduction drive st... Jan 5 2025, 03:53 PM
porschetub
I'm a HUGE believer in gear reduction drive s... Jan 6 2025, 04:17 PM
scallyk9 I've got Interstate AGM Group 5 batteries from... Jan 5 2025, 07:25 PM
Literati914 Great info, thanks everyone! I'm probably ... Jan 5 2025, 11:19 PM
technicalninja And here's a sign of the times...
I had to pu... Jan 8 2025, 02:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 08:15 PM |
