> CCA Requirements?
Literati914
post Jan 4 2025, 12:09 AM
I'll be picking up a flooded cell lead acid battery soon (budget oriented battery for a rear trunk relocation) and have been leaning towards a group 51R battery. I like this size because they are small - think Mazda Miata, small Honda Civics, Nissan GT-R, IIRC. However, I think the original group 34 had around 700 CCA [is that correct?] and the 51R tends to have a little less (425-/+). The first engine will be a 1.7, but then I'll probably upgrade fairly quickly, possibly before the typical battery dies.
I sort of recall the CCA demand being dependent on the needs of the starter.. or something like that. Anyone know for sure what our starters require, amp wise? And/Or Will the 425 CCA work?
technicalninja
post Jan 4 2025, 12:16 PM
51r will work fine (have to have good grounds/feed wiring)
I'd go AGM even in the trunk.
Walmart has what I'd buy
https://www.walmart.com/ip/EverStart-Platin...130452206?gQT=2
$180 and you can put it anywhere!
The stock location isn't bad...
Lots of the Miata crowd goes TINY batteries. Like 5lbs. batteries!
They seem to work pretty good too...
fixer34
post Jan 4 2025, 02:30 PM
QUOTE(technicalninja @ Jan 4 2025, 12:16 PM) *
Speaking of small batteries, I would like someone to explain how these lithium based 'jump start' kits with a battery the size of cigarette pack will start a car.
post Jan 4 2025, 02:39 PM
914-6 GT in waiting
QUOTE(fixer34 @ Jan 4 2025, 03:30 PM) *
I don’t know how but I know for a fact that they will. I use mine all the time to start cars at my shop.
Literati914   CCA Requirements?   Jan 4 2025, 12:09 AM
Superhawk996   Typical starter draw is about 100-200A under load ...   Jan 4 2025, 11:21 AM
technicalninja   51r will work fine (have to have good grounds/feed...   Jan 4 2025, 12:16 PM
fixer34   51r will work fine (have to have good grounds/fee...   Jan 4 2025, 02:30 PM
mepstein   [quote name='technicalninja' post='3184926' date=...   Jan 4 2025, 02:39 PM
Superhawk996   Speaking of small batteries, I would like someon...   Jan 4 2025, 03:04 PM
mlindner   Optima in the trunk but not small. Mark   Jan 4 2025, 12:51 PM
technicalninja   Speaking of small batteries, I would like someo...   Jan 4 2025, 03:21 PM
GregAmy   I am using this: https://www.batterywarehouseonlin...   Jan 4 2025, 06:03 PM
Literati914   51r will work fine (have to have good grounds/fee...   Jan 5 2025, 12:02 PM
Superhawk996   AGM without a doubt. Can mount in any orientati...   Jan 5 2025, 12:16 PM
mepstein   AGM without a doubt. Can mount in any orientat...   Jan 5 2025, 12:27 PM
porschetub   AGM without a doubt. Can mount in any orientat...   Jan 5 2025, 03:31 PM
zoomCat   Will the 425 CCA work? The factory battery was a...   Jan 5 2025, 01:00 PM
technicalninja   I'm a HUGE believer in gear reduction drive st...   Jan 5 2025, 03:53 PM
porschetub   I'm a HUGE believer in gear reduction drive s...   Jan 6 2025, 04:17 PM
scallyk9   I've got Interstate AGM Group 5 batteries from...   Jan 5 2025, 07:25 PM
Literati914   Great info, thanks everyone! I'm probably ...   Jan 5 2025, 11:19 PM
technicalninja   And here's a sign of the times... I had to pu...   Jan 8 2025, 02:04 PM
- Lo-Fi Version Time is now: 1st April 2026 - 08:22 PM
