| Literati914 |
Jan 4 2025, 12:09 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,235 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'll be picking up a flooded cell lead acid battery soon (budget oriented battery for a rear trunk relocation) and have been leaning towards a group 51R battery. I like this size because they are small - think Mazda Miata, small Honda Civics, Nissan GT-R, IIRC. However, I think the original group 34 had around 700 CCA [is that correct?] and the 51R tends to have a little less (425-/+). The first engine will be a 1.7, but then I'll probably upgrade fairly quickly, possibly before the typical battery dies.
I sort of recall the CCA demand being dependent on the needs of the starter.. or something like that. Anyone know for sure what our starters require, amp wise? And/Or Will the 425 CCA work? |
| Superhawk996 |
Jan 5 2025, 12:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
AGM without a doubt.
Can mount in any orientation. No corrosive off-gassing. |
| mepstein |
Jan 5 2025, 12:27 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,586 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
AGM without a doubt. Can mount in any orientation. No corrosive off-gassing. (IMG:style_emoticons/default/agree.gif) AGM for the win. |
Literati914 CCA Requirements? Jan 4 2025, 12:09 AM
Superhawk996 Typical starter draw is about 100-200A under load ... Jan 4 2025, 11:21 AM
technicalninja 51r will work fine (have to have good grounds/feed... Jan 4 2025, 12:16 PM
fixer34
51r will work fine (have to have good grounds/fee... Jan 4 2025, 02:30 PM
[quote name='technicalninja' post='3184926' date=... Jan 4 2025, 02:39 PM
Superhawk996
Speaking of small batteries, I would like someon... Jan 4 2025, 03:04 PM
mlindner Optima in the trunk but not small. Mark Jan 4 2025, 12:51 PM
technicalninja
Speaking of small batteries, I would like someo... Jan 4 2025, 03:21 PM
GregAmy I am using this:
https://www.batterywarehouseonlin... Jan 4 2025, 06:03 PM
Literati914
51r will work fine (have to have good grounds/fee... Jan 5 2025, 12:02 PM
porschetub
Can mount in any orientat... Jan 5 2025, 03:31 PM
zoomCat
The factory battery was a... Jan 5 2025, 01:00 PM
technicalninja I'm a HUGE believer in gear reduction drive st... Jan 5 2025, 03:53 PM
porschetub
I'm a HUGE believer in gear reduction drive s... Jan 6 2025, 04:17 PM
scallyk9 I've got Interstate AGM Group 5 batteries from... Jan 5 2025, 07:25 PM
Literati914 Great info, thanks everyone! I'm probably ... Jan 5 2025, 11:19 PM
technicalninja And here's a sign of the times...
I had to pu... Jan 8 2025, 02:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 08:17 PM |
