| mlwbob37 |
Jan 8 2025, 03:24 PM
Newbie ![]() Group: Members Posts: 3 Joined: 3-November 24 From: Los Gatos, CA Member No.: 28,446 Region Association: Northern California |
Hello 914 World! I am happy to say hello and introduce myself to the 914 World, as I recently became the owner of a '73 914 6 conversion that I found here in the classifieds. It's an original 2.0l car and I have the numbers matching motor in storage. In it's place is a 3.0l out of a '79 911 SC. The car was 95% done and now is a driver and on the streets while I sort out some known and some unknown issues. One of which is I don't have a parking brake any longer due to the installation of some beautiful, updated brake calipers from a Boxter/Cayman and 911 rotors. I have talked to Patrick Motorsports and a few local Bay Area Porsche experts and nobody has an easy or $ reasonable alternative. Any suggestions are greatly appreciated!!!
I have found the Wilwood Rear Brake kit for $3k. I have also found the option to go with OEM 914-6 rear brakes, which is also cost prohibitive. I really don't want to go backwards which is why I am asking all of you for some help. Much thanks! Mike (IMG:style_emoticons/default/biggrin.gif) |
| Steve |
Jan 8 2025, 05:18 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
There is a classic thread on this topic.
http://www.914world.com/bbs2/index.php?showtopic=4909 I used a thick piece of angle iron welded to the trailing arm, similar to a 911. In the article above they showed a modified 911 parking plate with a built in block. I would not recommend this unless you are just using it as a parking brake. In an emergency at speed I doubt that wimpy stop plate would prevent the shoes from braking loose and spin on the axle. |
mlwbob37 Hand brake for 6 conversion with updated brakes Jan 8 2025, 03:24 PM
mb911
Hello 914 World! I am happy to say hello and... Jan 8 2025, 03:29 PM
Root_Werks PO on my six conversion mocked up his own routing ... Jan 8 2025, 04:11 PM
Chris914n6 Basically you want the 911 drum brake setup. Boxst... Jan 8 2025, 04:14 PM
Montreal914 @[url=http://www.914world.com/bbs2/index.php?showu... Jan 17 2025, 09:03 PM
Cairo94507 One other possibility might be a hydraulic line-lo... Jan 8 2025, 04:39 PM
One other possibility might be a hydraulic line-l... Jan 8 2025, 04:57 PM
porschetub
http://w... Jan 18 2025, 01:18 PM
930cabman I am using the stock /4 setup with my 2.7/6 conver... Jan 8 2025, 05:27 PM
Steve
I am using the stock /4 setup with my 2.7/6 conve... Jan 8 2025, 05:41 PM
WFG You can still find 914 6 rear calipers just not as... Jan 17 2025, 02:47 PM
burton73 The easy and best in my option it to get a pair of... Jan 17 2025, 04:13 PM
burton73 Point of reference: These are the trailing arms th... Jan 17 2025, 04:50 PM
technicalninja Whole bundle. 914-6GT and vented rotors/performanc... Jan 17 2025, 05:15 PM
burton73
Whole bundle. 914-6GT and vented rotors/performan... Jan 17 2025, 05:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:20 PM |
