| Jezibel |
Jan 7 2025, 08:14 PM
Das Echte POORSCHE Fahrer ![]() ![]() Group: Members Posts: 69 Joined: 21-January 24 From: Northern California Member No.: 27,868 Region Association: Northern California |
OK, guys. Here we go again. I just bought the AUTO ATLANTA 'Euro Turn Signal conversion assembly', which is a set of two bulb holders made from stock aluminum sheeting and bent to (supposedly) conform to the lower section of the US type turn signal assembly housing. After quite a bit of trying to make them fit, I finally gave up and am turning to the forum (once again) to find out exactly what's going with this supposedly "...easy conversion set that has satisfied thousands of Auto Atlanta purchasers"...?
It's pretty clear that however they are supposed to 'easily fit' the turn signal housings, they absolutely do not. Any help with this annoying matter would be most appreciated. Frankly, I'm starting to get a teensy bit irritated with some of the items I've gotten from AUTO ATLANTA (including a pricey replica 914GT double grill engine cover that was rather hastily and sloppily put together), recently. Nuff sed, but any insights on this would be helpful... ![]() |
| Cairo94507 |
Jan 9 2025, 01:22 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,801 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I have Jerry's (Spoke) LED's in all of my lights. Literally took me 30 minutes to install all of them and be done. No install issues at all. (IMG:style_emoticons/default/beerchug.gif)
Jezibel 914 Front Turn Signal Assembly European conversion kit Jan 7 2025, 08:14 PM
dr914@autoatlanta.com patrik hess in germany makes them and he does a go... Jan 8 2025, 02:30 PM
Jezibel
patrik hess in germany makes them and he does a g... Jan 8 2025, 04:08 PM
yellowporky Those euro turn signal kits have been available fo... Jan 8 2025, 03:16 PM
Jezibel
Those euro turn signal kits have been available f... Jan 8 2025, 04:15 PM
Spoke You could always go LED and just drop these boards... Jan 8 2025, 08:42 PM
You could always go LED and just drop these board... Jan 9 2025, 09:30 AM
rgolia
You could always go LED and just drop these boar... Jan 10 2025, 08:04 AM
Jezibel
You could always go LED and just drop these board... Jan 9 2025, 12:59 PM
mepstein If you have any questions about installing, Jerry/... Jan 9 2025, 01:18 PM
peteyd I was tinkering with this project a month or two b... Jan 9 2025, 01:26 PM
eric9144
I have Jerry's (Spoke) LED's in all of my... Jan 9 2025, 02:18 PM
porschetub
OK, guys. Here we go again. I just bought the AUT... Jan 9 2025, 03:03 PM
mb911 Martin (last name I don’t recall) use to make an... Jan 9 2025, 04:27 PM
tygaboy
Martin (last name I don’t recall) use to make a... Jan 9 2025, 04:54 PM
burton73 Just as a point of reference these are pictures ar... Jan 9 2025, 04:50 PM
Spoke
Just as a point of reference these are pictures a... Jan 12 2025, 03:54 PM
ClayPerrine
Clay, would you want to try out these LEDs? I th... Jan 13 2025, 06:19 AM
Jezibel WIZARD stuff, Jerry! I am in awe of your multi... Jan 13 2025, 09:16 AM
SKL1 What spoke said- have them on both cars and it... Jan 9 2025, 05:57 PM
Spoke
OK, guys. Here we go again. I just bought the AUT... Jan 9 2025, 08:13 PM
mb911 Sounds like I need to get some cores and start off... Jan 10 2025, 05:20 AM
Geezer914 Made my own out of polished aluminum sheet. Jan 10 2025, 06:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th November 2026 - 10:58 PM |
