| 914incali |
Apr 2 2024, 11:07 AM
Newbie ![]() Group: Members Posts: 4 Joined: 16-February 24 From: bakersfield Member No.: 27,944 Region Association: None
Picked up a 76 out of texas that had been converted to single carb that just doesn't run very well. I decided to convert back to original FI, essentially everything is gone and I am working on understanding the system. I guess my first question is where does the fuel pump draw power from? there is a single black wire underneath the fuel tank that has no power to it but all the relays have been removed and Im waiting on those from pelican
| Ron914 |
Jan 12 2025, 10:40 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 562 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
When I first assembled my motor I followed this diagram .Since I did not disassemble the motor and was a newby I thought this diagram was correct for all cars 74-76 and I bought a anti-flashback valve from Bruce .I later found out from someone that a 76 did not use the anti-flashback ,however my valve covers have 13mm hose connections on them . I was not sure the what the valve covers should be connected to so the valve covers are open to air now . In this diagram they show connection between the anti-flashback and the valve covers . Do I need to remove those covers and purchase ones without holes ?
| Ron914 |
Jan 12 2025, 10:56 AM
When I first assembled my motor I followed this diagram .Since I did not disassemble the motor and was a newby I thought this diagram was correct for all cars 74-76 and I bought a anti-flashback valve from Bruce .I later found out from someone that a 76 did not use the anti-flashback ,however my valve covers have 13mm hose connections on them . I was not sure the what the valve covers should be connected to so the valve covers are open to air now . In this diagram they show connection between the anti-flashback and the valve covers . Do I need to remove those covers and purchase ones without holes ? I did buy a set of aftermarket valve covers from a members garage sale but they did not come with mounting hardware .I am still trying to locate the proper hardware but maybe I would be better off located the proper stock covers . Forgive all my post post photos as I am practicing adding photos so I can get this memorized . |
914incali 1976 fuel injection questions Apr 2 2024, 11:07 AM
dr914@autoatlanta.com power is from the relay board in the engine compar... Apr 2 2024, 11:18 AM
914incali I have a complete injection system and am waiting ... Apr 2 2024, 11:34 AM
rjames Black and red= power, brown=ground to chassis.
Apr 2 2024, 11:54 AM
914incali
... Apr 2 2024, 12:12 PM
JeffBowlsby Single brown ground cable for the fuel pump is se... Apr 2 2024, 01:15 PM
914incali yes its out of a 73 2.0, im not to worried about s... Apr 2 2024, 01:31 PM
fiacra
yes its out of a 73 2.0, im not to worried about ... Apr 2 2024, 10:02 PM
L-Jet914
yes its out of a 73 2.0, im not to worried about ... Oct 10 2024, 11:33 PM
burton73 The problem is you are in California, and you need... Apr 2 2024, 01:39 PM
Karl R Also that is the wrong FI for your car. Your 1976... Apr 3 2024, 07:04 PM
JeffBowlsby
Also that is the wrong FI for your car. Your 197... Apr 3 2024, 07:23 PM
wonkipop
Also that is the wrong FI for your car. Your 19... Apr 4 2024, 06:10 PM
Ron914
[quote name='JeffBowlsby' post='3137731' date='Ap... Oct 9 2024, 12:42 PM
wonkipop
[quote name='JeffBowlsby' post='3137731' date='A... Oct 9 2024, 04:15 PM
L-Jet914
[quote name='JeffBowlsby' post='3137731' date='A... Oct 10 2024, 11:17 PM
r_towle 76 is djet.
I happen to have one here if you need... Apr 3 2024, 08:23 PM
Karl R I guess I'm starting to slip. I thought they s... Apr 4 2024, 04:39 PM
r_towle
I guess I'm starting to slip. I thought they ... Apr 4 2024, 05:31 PM
JeffBowlsby For smog purposes CA-only model 1975-76 914s also ... Oct 9 2024, 05:15 PM
wonkipop @Ron914
here is what CARB would have on file for... Oct 9 2024, 08:06 PM
Ron914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Oct 10 2024, 04:58 PM
wonkipop
well i can only speak as an australian down here... Oct 10 2024, 06:57 PM
fiacra
[quote name='wonkipop' post='3172034' date='Oct 9... Oct 10 2024, 11:14 PM
Ron914
[quote name='wonkipop' post='3172034' date='Oct ... Oct 10 2024, 11:47 PM
L-Jet914
[quote name='fiacra' post='3172200' date='Oct 11 ... Oct 10 2024, 11:57 PM
wonkipop
[quote name='fiacra' post='3172200' date='Oct 11 ... Oct 11 2024, 12:41 AM
JeffBowlsby Did paperwork from the previous smog tests come wi... Oct 10 2024, 05:28 PM
wonkipop on the question of how the previous owner got the ... Oct 10 2024, 07:07 PM
wonkipop @JeffBowlsby
you always throw up interesting inf... Oct 10 2024, 07:22 PM
JeffBowlsby Yes! It’s in the Service &Training manu... Oct 10 2024, 07:48 PM
JeffBowlsby I have at least one 75 CA 2.0L with the SL box on ... Oct 10 2024, 07:58 PM
wonkipop
I have at least one 75 CA 2.0L with the SL box on... Oct 10 2024, 09:44 PM
JeffBowlsby
[quote name='JeffBowlsby' post='3172179' date='Oc... Oct 10 2024, 10:15 PM
wonkipop
[quote name='JeffBowlsby' post='3172179' date='O... Oct 11 2024, 12:38 AM
Ron914 When I bought the car I had to go to the DMV and p... Oct 10 2024, 10:47 PM
L-Jet914 If you have a plate number you can see the pass/fa... Oct 10 2024, 11:03 PM
L-Jet914 Everything required for a California certified 197... Oct 10 2024, 11:28 PM
wonkipop
Everything required for a California certified 19... Oct 11 2024, 12:39 AM
930cabman Glad I don't live in Cali Oct 11 2024, 05:04 AM
fiacra
It ain't bad ... Oct 11 2024, 03:29 PM
emerygt350 Absolutely agree. Drives me crazy living in NY tr... Oct 11 2024, 06:35 PM
davep So Ron, what is the current situation? Jan 5 2025, 03:30 PM
fiacra @914incali
[b]@[url=http://www.914world.com/bbs2... Jan 5 2025, 03:57 PM
Ron914 Thanks for checking in . I am still working on my ... Jan 6 2025, 12:28 PM
Ron914 I believe it was @ emerygt350 that asked @slapsho... Jan 6 2025, 12:35 PM
JeffBowlsby Post a photo of that oblong hole so we clearly und... Jan 6 2025, 12:48 PM
rjames
Post a photo of that oblong hole so we clearly un... Jan 6 2025, 02:02 PM
emerygt350 If the idle adjust screw no longer closes off the ... Jan 6 2025, 02:54 PM
Ron914 I would really like to post a photo or video but l... Jan 6 2025, 04:44 PM
burton73
I would really like to post a photo or video but ... Jan 6 2025, 06:19 PM
Ron914
[quote name='Ron914' post='3185256' date='Jan 6 2... Jan 6 2025, 06:37 PM
burton73 Sending this to Rick as well.
You are very close... Jan 6 2025, 09:28 PM
emerygt350 You are all good with that butterfly. That is how... Jan 6 2025, 06:08 PM
Ron914
You are all good with that butterfly. That is ho... Jan 6 2025, 07:04 PM
technicalninja Thanks Bob! Jan 7 2025, 09:20 AM
rjames
The butterfly should have two screws that hold t... Jan 7 2025, 11:05 AM
emerygt350
The butterfly should have two screws that hold ... Jan 7 2025, 12:47 PM
Ron914
The butterfly should have two screws that hold... Jan 7 2025, 02:34 PM
emerygt350 At the current state I would leave it in the hole,... Jan 7 2025, 07:56 PM
Ron914 Hello ,
I covered the inside idle screw air intake... Jan 11 2025, 06:12 PM
emerygt350 Great news. What a nice looking car! Just ou... Jan 11 2025, 07:18 PM
Ron914
Great news. What a nice looking car! Just o... Jan 11 2025, 08:00 PM
fiacra Good luck on Monday. Fingers crossed. If it does... Jan 11 2025, 07:41 PM
JeffBowlsby You might also try a smoke pen/pencil. Lower inve... Jan 11 2025, 08:48 PM
emerygt350 Is your vacuum retard can on the distributor hooke... Jan 11 2025, 09:24 PM
Ron914
Is your vacuum retard can on the distributor hook... Jan 12 2025, 09:23 AM
Ron914 Lets try the photo again Jan 12 2025, 09:39 AM
JeffBowlsby Hose 10 is not connected to anything on a 1974-76 ... Jan 12 2025, 09:53 AM
Ron914
Hose 10 is not connected to anything on a 1974-76... Jan 12 2025, 10:22 AM
Ron914 I don't think that this is the source of my va... Jan 12 2025, 10:23 AM
Ron914 should the #10 hose be plugged or left open to air... Jan 12 2025, 10:24 AM
Ron914
should the #10 hose be plugged or left open to ai... Jan 12 2025, 10:32 AM
rjames
[quote name='Ron914' post='3186354' date='Jan 12 ... Jan 12 2025, 12:54 PM
emerygt350 We should walk you through all the vacuum hoses. ... Jan 12 2025, 02:02 PM
emerygt350
We should walk you through all the vacuum hoses. ... Jan 12 2025, 02:05 PM
Ron914
We should walk you through all the vacuum hoses.... Jan 12 2025, 02:58 PM
rjames
‘75/76 2.0 cars did not have the PCV valve. Jan 12 2025, 02:37 PM
emerygt350
... Jan 12 2025, 03:50 PM
emerygt350 And... That decel keeps you from blowing out your ... Jan 12 2025, 03:54 PM
JeffBowlsby Good point that this is a ‘76 car, the 75-76 car... Jan 12 2025, 07:32 PM
Ron914 Hi Jeff ,
Yes ,as I mentioned I have a federally c... Jan 12 2025, 08:04 PM
emerygt350 They were always trying different things to handle... Jan 12 2025, 08:31 PM
Ron914
They were always trying different things to handl... Jan 12 2025, 08:40 PM
emerygt350 Anyone got a good 76 vacuum map? I am always nerv... Jan 12 2025, 08:33 PM
Ron914 The exciting thing for me is we believe this is a ... Jan 12 2025, 08:54 PM
Ron914 Hello @914incali
I also have a 76 914 I am tryin... Jan 12 2025, 09:40 PM
Ron914 @emerygt350
I think this will be my last post in ... Jan 14 2025, 09:35 AM
emerygt350 Yes, probably a good idea. But you know now that ... Jan 14 2025, 03:36 PM
Ron914
Yes, probably a good idea. But you know now that... Jan 14 2025, 04:18 PM
emerygt350 Your car doesn't have an advance port, that wo... Jan 14 2025, 04:30 PM
emerygt350 If you have your advance hose hooked to any kind o... Jan 14 2025, 04:32 PM
Ron914
If you have your advance hose hooked to any kind ... Jan 14 2025, 08:24 PM
emerygt350 That is good news. Progress! I will wait for... Jan 15 2025, 06:25 AM
brant Please don’t
“Time by ear”
Remark the timi... Jan 15 2025, 10:53 AM
Ron914
Please don’t
“Time by ear”
Remark the tim... Jan 15 2025, 11:28 AM
914werke I started updating this one based on an unmolested... Jan 15 2025, 11:17 AM
Ron914
I started updating this one based on an unmoleste... Jan 15 2025, 12:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2026 - 02:50 AM |
