| randyt914 |
Jan 11 2025, 06:19 PM
Member ![]() ![]() Group: Members Posts: 124 Joined: 6-April 06 From: truckee ca Member No.: 5,832 |
I would like some advice as to the best accelerator cable mount and location for a 74 type 4 i am working on. i've only owned fi so any help will help. Also is there a certain cable shroud part that holds the cable shroud to the mounting bar allowing little to no resistance for the cable to move freely. Thanks (IMG:style_emoticons/default/sawzall-smiley.gif)
| technicalninja |
Jan 12 2025, 02:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Thanks!
Logical! I'd bet that works pretty good as an AAR! That might be a solution for old AARs on L-jet systems. The "new" non OEM AARs haven't worked for me. You'd have to control it with an Arduino but that could work! |
randyt914 hex bar to accel cable mounting and advice please. Jan 11 2025, 06:19 PM
randyt914 cable mount and cable end Jan 11 2025, 06:35 PM
930cabman your throttle cable needs a threaded end to secure... Jan 11 2025, 06:43 PM
randyt914 i was wondering what the part looked like...and wh... Jan 11 2025, 07:03 PM
randyt914
your throttle cable needs a threaded end to secur... Jan 11 2025, 07:07 PM
Aerostatwv 914Werke has a picture of it mounted: https://914w... Jan 11 2025, 08:32 PM
randyt914 I got her figured out thanks now I just need that ... Jan 11 2025, 09:32 PM
r_towle Bicycle shop Jan 11 2025, 10:16 PM
Shivers It is too dark for me to check but this is close. ... Jan 12 2025, 07:37 AM
randyt914 thank you and hope you are safe from the fires....... Jan 12 2025, 09:51 AM
randyt914 i have to give it to the local bike shop....aprox ... Jan 12 2025, 12:27 PM
914werke i was wondering what the part looked like...and w... Jan 12 2025, 01:12 PM
technicalninja
i was wondering what the part looked like...and ... Jan 12 2025, 01:56 PM
randyt914
[quote name='914werke' post='3186374' date='Jan 1... Jan 12 2025, 05:03 PM
914werke Megasquirt install
Non-stepper AAR for warm up Jan 12 2025, 02:17 PM
technicalninja Sorry, that was what we call a thread drift and ha... Jan 12 2025, 05:17 PM
randyt914 Never apologize as i consider it a chance to learn... Jan 13 2025, 12:44 PM
930cabman
Never apologize as i consider it a chance to lear... Jan 13 2025, 12:58 PM
randyt914 there was a filter added and i noticed that the re... Jan 13 2025, 01:12 PM
randyt914 floats were correct at the first running...still h... Jan 13 2025, 01:14 PM
technicalninja :agree: :agree: :agree:
Those are all good tip... Jan 13 2025, 01:19 PM
randyt914 [quote name='technicalninja' date='Jan... Jan 13 2025, 01:48 PM
randyt914 here is the fire up on the trailer.... :cheer: Jan 13 2025, 01:28 PM
930cabman
... Jan 13 2025, 02:17 PM
randyt914
here is the fire up on the trailer.... :cheer:... Jan 13 2025, 02:22 PM
Jack Standz Yes, have a blanket ready that you can smother a f... Jan 13 2025, 02:04 PM
randyt914 I have run this already for the initial leak test ... Jan 13 2025, 02:15 PM
Jack Standz Yes, you can plug the return fuel line. But, it... Jan 13 2025, 02:13 PM
randyt914
Yes, you can plug the return fuel line. But, it... Jan 13 2025, 02:18 PM
randyt914 this is my motivation to finish ....71 2316 raby 1... Jan 13 2025, 02:28 PM
930cabman I like 1608 lbs, just watch what you have for dinn... Jan 13 2025, 03:16 PM
randyt914
I like 1608 lbs, just watch what you have for din... Jan 13 2025, 03:30 PM
technicalninja I'm sorry!
You have a serious build.
You... Jan 13 2025, 03:43 PM
randyt914 You have a serious build.
Your carbs may be much ... Jan 13 2025, 04:52 PM
Jack Standz
I have run this already for the initial leak test... Jan 13 2025, 05:50 PM
randyt914
I have run this already for the initial leak tes... Jan 13 2025, 06:44 PM
technicalninja I'd run that return style.
Those carbs are pe... Jan 13 2025, 06:27 PM
randyt914
Those carbs are p... Jan 13 2025, 06:41 PM
technicalninja Something like this.
https://fuelab.com/51504-fue... Jan 13 2025, 07:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th October 2026 - 02:33 AM |
