> hex bar to accel cable mounting and advice please., looking for ideas re acc cable mount
randyt914
post Jan 11 2025, 06:19 PM
I would like some advice as to the best accelerator cable mount and location for a 74 type 4 i am working on. i've only owned fi so any help will help. Also is there a certain cable shroud part that holds the cable shroud to the mounting bar allowing little to no resistance for the cable to move freely. Thanks (IMG:style_emoticons/default/sawzall-smiley.gif)
randyt914
post Jan 13 2025, 01:28 PM
here is the fire up on the trailer.... Attached File  IMG_2329.mov ( 3.76mb ) Number of downloads: 57
(IMG:style_emoticons/default/cheer.gif)
randyt914   hex bar to accel cable mounting and advice please.   Jan 11 2025, 06:19 PM
randyt914   cable mount and cable end   Jan 11 2025, 06:35 PM
930cabman   your throttle cable needs a threaded end to secure...   Jan 11 2025, 06:43 PM
randyt914   i was wondering what the part looked like...and wh...   Jan 11 2025, 07:03 PM
randyt914   your throttle cable needs a threaded end to secur...   Jan 11 2025, 07:07 PM
Aerostatwv   914Werke has a picture of it mounted: https://914w...   Jan 11 2025, 08:32 PM
randyt914   I got her figured out thanks now I just need that ...   Jan 11 2025, 09:32 PM
r_towle   Bicycle shop   Jan 11 2025, 10:16 PM
Shivers   It is too dark for me to check but this is close. ...   Jan 12 2025, 07:37 AM
randyt914   thank you and hope you are safe from the fires.......   Jan 12 2025, 09:51 AM
randyt914   i have to give it to the local bike shop....aprox ...   Jan 12 2025, 12:27 PM
914werke   i was wondering what the part looked like...and w...   Jan 12 2025, 01:12 PM
technicalninja   i was wondering what the part looked like...and ...   Jan 12 2025, 01:56 PM
randyt914   [quote name='914werke' post='3186374' date='Jan 1...   Jan 12 2025, 05:03 PM
914werke   Megasquirt install Non-stepper AAR for warm up   Jan 12 2025, 02:17 PM
technicalninja   Thanks! Logical! I'd bet that works ...   Jan 12 2025, 02:28 PM
technicalninja   Sorry, that was what we call a thread drift and ha...   Jan 12 2025, 05:17 PM
randyt914   Never apologize as i consider it a chance to learn...   Jan 13 2025, 12:44 PM
930cabman   Never apologize as i consider it a chance to lear...   Jan 13 2025, 12:58 PM
randyt914   there was a filter added and i noticed that the re...   Jan 13 2025, 01:12 PM
randyt914   floats were correct at the first running...still h...   Jan 13 2025, 01:14 PM
technicalninja   :agree: :agree: :agree: Those are all good tip...   Jan 13 2025, 01:19 PM
randyt914   [quote name='technicalninja' date='Jan...   Jan 13 2025, 01:48 PM
randyt914   here is the fire up on the trailer.... :cheer:   Jan 13 2025, 01:28 PM
930cabman   here is the fire up on the trailer.... :cheer: ...   Jan 13 2025, 02:17 PM
randyt914   here is the fire up on the trailer.... :cheer:...   Jan 13 2025, 02:22 PM
Jack Standz   Yes, have a blanket ready that you can smother a f...   Jan 13 2025, 02:04 PM
randyt914   I have run this already for the initial leak test ...   Jan 13 2025, 02:15 PM
Jack Standz   Yes, you can plug the return fuel line. But, it...   Jan 13 2025, 02:13 PM
randyt914   Yes, you can plug the return fuel line. But, it...   Jan 13 2025, 02:18 PM
randyt914   this is my motivation to finish ....71 2316 raby 1...   Jan 13 2025, 02:28 PM
930cabman   I like 1608 lbs, just watch what you have for dinn...   Jan 13 2025, 03:16 PM
randyt914   I like 1608 lbs, just watch what you have for din...   Jan 13 2025, 03:30 PM
technicalninja   I'm sorry! You have a serious build. You...   Jan 13 2025, 03:43 PM
randyt914   You have a serious build. Your carbs may be much ...   Jan 13 2025, 04:52 PM
Jack Standz   I have run this already for the initial leak test...   Jan 13 2025, 05:50 PM
randyt914   I have run this already for the initial leak tes...   Jan 13 2025, 06:44 PM
technicalninja   I'd run that return style. Those carbs are pe...   Jan 13 2025, 06:27 PM
randyt914   I'd run that return style. Those carbs are p...   Jan 13 2025, 06:41 PM
technicalninja   Something like this. https://fuelab.com/51504-fue...   Jan 13 2025, 07:14 PM
- Lo-Fi Version Time is now: 15th October 2026 - 02:32 AM
