> hex bar to accel cable mounting and advice please., looking for ideas re acc cable mount
randyt914
post Jan 11 2025, 06:19 PM
I would like some advice as to the best accelerator cable mount and location for a 74 type 4 i am working on. i've only owned fi so any help will help. Also is there a certain cable shroud part that holds the cable shroud to the mounting bar allowing little to no resistance for the cable to move freely. Thanks (IMG:style_emoticons/default/sawzall-smiley.gif)
technicalninja
post Jan 13 2025, 01:19 PM
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
Those are all good tips.
Get you ignition system dialed in properly. Many threads on this.
Verify engine compression, valve adjustment.
What carbs? What venturis?
The incorrectly sized carbs and ESPECIALLY venturis, will make your job significantly more difficult.
A street 2.0l will work best on 40s with 27-28mm vents.
Another thing I would not live without today is a wide band oxygen sensor set up.
I've had 40 years of tuning and reading plugs and a WB puts me to shame.
In my book it is a required mod!
Most important is to be overly cautious regarding fire. With carbs I'd have a cabin mounted FE.
Keep big ones close by when you're working on the car.
If you are prepared and expecting fire you will NEVER have to use the extinguisher.
I LIKE those "fire blankets" they sell for your kitchen. Those cover engine compartments nicely and if you get the fire out in the first 15 seconds there is usually no or limited damage.
Setting off a 10 lb. extinguisher means 3-4 hours of clean up!
randyt914
post Jan 13 2025, 01:48 PM
[quote name='technicalninja' date='Jan 13 2025, 11:19 AM' post='3186562']
great advice i will be looking into this. I am a 1/2 owner on this car and am enjoying the punch list work and am learning a few things along the way. I just added a new dash and will go through the guages and shift linkage ....and will do all fire ups outside with a small and large fe handy! now im gonna buy a fire blanket.... the engine was rebuilt (not by me but by my buddy Chuck in the vid.) and assembled at the shop. I was there for the valve job and the timing. I don't own a float for carbs but ill buy one of those too! This is my 6th 914 in 25+yrs. the older i get the more i am interested in the "whys and how" thus my reasoning for owning 3 currently. Not sure of the venturi size. I know it is an e case but do not know the size of the pncs or the specs on the heads. No real blueprinting....Ill be handing this back to my business partner so he can enjoy this ride. I also need a peace of mind on trips so i do not have to wrench on my way to coffee and cars. (IMG:style_emoticons/default/drunk.gif) As for ignition we have a msd 6a. That will be an entire new thread...
randyt914   hex bar to accel cable mounting and advice please.   Jan 11 2025, 06:19 PM
randyt914   cable mount and cable end   Jan 11 2025, 06:35 PM
930cabman   your throttle cable needs a threaded end to secure...   Jan 11 2025, 06:43 PM
randyt914   i was wondering what the part looked like...and wh...   Jan 11 2025, 07:03 PM
randyt914   your throttle cable needs a threaded end to secur...   Jan 11 2025, 07:07 PM
Aerostatwv   914Werke has a picture of it mounted: https://914w...   Jan 11 2025, 08:32 PM
randyt914   I got her figured out thanks now I just need that ...   Jan 11 2025, 09:32 PM
r_towle   Bicycle shop   Jan 11 2025, 10:16 PM
Shivers   It is too dark for me to check but this is close. ...   Jan 12 2025, 07:37 AM
randyt914   thank you and hope you are safe from the fires.......   Jan 12 2025, 09:51 AM
randyt914   i have to give it to the local bike shop....aprox ...   Jan 12 2025, 12:27 PM
914werke   i was wondering what the part looked like...and w...   Jan 12 2025, 01:12 PM
technicalninja   i was wondering what the part looked like...and ...   Jan 12 2025, 01:56 PM
randyt914   [quote name='914werke' post='3186374' date='Jan 1...   Jan 12 2025, 05:03 PM
914werke   Megasquirt install Non-stepper AAR for warm up   Jan 12 2025, 02:17 PM
technicalninja   Thanks! Logical! I'd bet that works ...   Jan 12 2025, 02:28 PM
technicalninja   Sorry, that was what we call a thread drift and ha...   Jan 12 2025, 05:17 PM
randyt914   Never apologize as i consider it a chance to learn...   Jan 13 2025, 12:44 PM
930cabman   Never apologize as i consider it a chance to lear...   Jan 13 2025, 12:58 PM
randyt914   there was a filter added and i noticed that the re...   Jan 13 2025, 01:12 PM
randyt914   floats were correct at the first running...still h...   Jan 13 2025, 01:14 PM
technicalninja   :agree: :agree: :agree: Those are all good tip...   Jan 13 2025, 01:19 PM
randyt914   [quote name='technicalninja' date='Jan...   Jan 13 2025, 01:48 PM
randyt914   here is the fire up on the trailer.... :cheer:   Jan 13 2025, 01:28 PM
930cabman   here is the fire up on the trailer.... :cheer: ...   Jan 13 2025, 02:17 PM
randyt914   here is the fire up on the trailer.... :cheer:...   Jan 13 2025, 02:22 PM
Jack Standz   Yes, have a blanket ready that you can smother a f...   Jan 13 2025, 02:04 PM
randyt914   I have run this already for the initial leak test ...   Jan 13 2025, 02:15 PM
Jack Standz   Yes, you can plug the return fuel line. But, it...   Jan 13 2025, 02:13 PM
randyt914   Yes, you can plug the return fuel line. But, it...   Jan 13 2025, 02:18 PM
randyt914   this is my motivation to finish ....71 2316 raby 1...   Jan 13 2025, 02:28 PM
930cabman   I like 1608 lbs, just watch what you have for dinn...   Jan 13 2025, 03:16 PM
randyt914   I like 1608 lbs, just watch what you have for din...   Jan 13 2025, 03:30 PM
technicalninja   I'm sorry! You have a serious build. You...   Jan 13 2025, 03:43 PM
randyt914   You have a serious build. Your carbs may be much ...   Jan 13 2025, 04:52 PM
Jack Standz   I have run this already for the initial leak test...   Jan 13 2025, 05:50 PM
randyt914   I have run this already for the initial leak tes...   Jan 13 2025, 06:44 PM
technicalninja   I'd run that return style. Those carbs are pe...   Jan 13 2025, 06:27 PM
randyt914   I'd run that return style. Those carbs are p...   Jan 13 2025, 06:41 PM
technicalninja   Something like this. https://fuelab.com/51504-fue...   Jan 13 2025, 07:14 PM
- Lo-Fi Version Time is now: 15th October 2026 - 02:32 AM
