> hex bar to accel cable mounting and advice please., looking for ideas re acc cable mount
randyt914
post Jan 11 2025, 06:19 PM
I would like some advice as to the best accelerator cable mount and location for a 74 type 4 i am working on. i've only owned fi so any help will help. Also is there a certain cable shroud part that holds the cable shroud to the mounting bar allowing little to no resistance for the cable to move freely. Thanks (IMG:style_emoticons/default/sawzall-smiley.gif)
Jack Standz
post Jan 13 2025, 02:04 PM
Yes, have a blanket ready that you can smother a fire with or even better a halon fire extinguisher. Especially with carburetors with air filters removed (swapping main jets, etc.).
Last year,, somebody (OK, me) forgot to reinstall the refurbished injectors into the 968 cab and tried to start the car. Grabbed a cloth bag and threw it over the resulting gasoline fire. Fire didn't completely go out, so hit it with one of the dry chemical fire extinguishers that were hanging on the wall. Fire went out, but as technicalninja says, it took hours to clean out the mess. A steam cleaning machine helps.
Honestly, there was some panic involved, especially when the cloth bag didn't put out the fire. Otherwise, I probably would have grabbed the halon extinguisher from inside the 968. Fortunately, only minor melting of the spark plug wire cover (something like $31? To replace).
When I was a kid, a friend of my dad started a fire in his garage that caused a lot of damage and could easily have burnt the whole house down. So, please be careful out there.
randyt914
post Jan 13 2025, 02:15 PM
I have run this already for the initial leak test and will not start this in my garage untill i feel it is safe and everything has been gone through. I had help tuning the carbs. The air filters are on now as the hex bar has been moved to the rear of the carbs. I will double spring each carb to shut the butterflys. I was wondering do you need to plug the return fuel line at the firewall? what is the normal process for the return fuel line when modifying to dual carbs? and do you add the fpr before or after the fuel filter? i see you are in the bay area..i am in the east bay alamo area.
randyt914   hex bar to accel cable mounting and advice please.   Jan 11 2025, 06:19 PM
randyt914   cable mount and cable end   Jan 11 2025, 06:35 PM
930cabman   your throttle cable needs a threaded end to secure...   Jan 11 2025, 06:43 PM
randyt914   i was wondering what the part looked like...and wh...   Jan 11 2025, 07:03 PM
randyt914   your throttle cable needs a threaded end to secur...   Jan 11 2025, 07:07 PM
Aerostatwv   914Werke has a picture of it mounted: https://914w...   Jan 11 2025, 08:32 PM
randyt914   I got her figured out thanks now I just need that ...   Jan 11 2025, 09:32 PM
r_towle   Bicycle shop   Jan 11 2025, 10:16 PM
Shivers   It is too dark for me to check but this is close. ...   Jan 12 2025, 07:37 AM
randyt914   thank you and hope you are safe from the fires.......   Jan 12 2025, 09:51 AM
randyt914   i have to give it to the local bike shop....aprox ...   Jan 12 2025, 12:27 PM
914werke   i was wondering what the part looked like...and w...   Jan 12 2025, 01:12 PM
technicalninja   i was wondering what the part looked like...and ...   Jan 12 2025, 01:56 PM
randyt914   [quote name='914werke' post='3186374' date='Jan 1...   Jan 12 2025, 05:03 PM
914werke   Megasquirt install Non-stepper AAR for warm up   Jan 12 2025, 02:17 PM
technicalninja   Thanks! Logical! I'd bet that works ...   Jan 12 2025, 02:28 PM
technicalninja   Sorry, that was what we call a thread drift and ha...   Jan 12 2025, 05:17 PM
randyt914   Never apologize as i consider it a chance to learn...   Jan 13 2025, 12:44 PM
930cabman   Never apologize as i consider it a chance to lear...   Jan 13 2025, 12:58 PM
randyt914   there was a filter added and i noticed that the re...   Jan 13 2025, 01:12 PM
randyt914   floats were correct at the first running...still h...   Jan 13 2025, 01:14 PM
technicalninja   :agree: :agree: :agree: Those are all good tip...   Jan 13 2025, 01:19 PM
randyt914   [quote name='technicalninja' date='Jan...   Jan 13 2025, 01:48 PM
randyt914   here is the fire up on the trailer.... :cheer:   Jan 13 2025, 01:28 PM
930cabman   here is the fire up on the trailer.... :cheer: ...   Jan 13 2025, 02:17 PM
randyt914   here is the fire up on the trailer.... :cheer:...   Jan 13 2025, 02:22 PM
Jack Standz   Yes, have a blanket ready that you can smother a f...   Jan 13 2025, 02:04 PM
randyt914   I have run this already for the initial leak test ...   Jan 13 2025, 02:15 PM
Jack Standz   Yes, you can plug the return fuel line. But, it...   Jan 13 2025, 02:13 PM
randyt914   Yes, you can plug the return fuel line. But, it...   Jan 13 2025, 02:18 PM
randyt914   this is my motivation to finish ....71 2316 raby 1...   Jan 13 2025, 02:28 PM
930cabman   I like 1608 lbs, just watch what you have for dinn...   Jan 13 2025, 03:16 PM
randyt914   I like 1608 lbs, just watch what you have for din...   Jan 13 2025, 03:30 PM
technicalninja   I'm sorry! You have a serious build. You...   Jan 13 2025, 03:43 PM
randyt914   You have a serious build. Your carbs may be much ...   Jan 13 2025, 04:52 PM
Jack Standz   I have run this already for the initial leak test...   Jan 13 2025, 05:50 PM
randyt914   I have run this already for the initial leak tes...   Jan 13 2025, 06:44 PM
technicalninja   I'd run that return style. Those carbs are pe...   Jan 13 2025, 06:27 PM
randyt914   I'd run that return style. Those carbs are p...   Jan 13 2025, 06:41 PM
technicalninja   Something like this. https://fuelab.com/51504-fue...   Jan 13 2025, 07:14 PM
- Lo-Fi Version Time is now: 15th October 2026 - 02:30 AM
