I need a measurement..., from a V8 converted 914 |
bondo |
Feb 2 2005, 09:59 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Can someone measure from the flat surface the intake manifold seals to (ya know, the one you have to put a bead of silicone on, lightly bolt up the manifold, let it set, then torque it down only to have it leak anyways) to the underside of the engine lid?
I need to make some intake manifold mods for my LT1. There was a rumor that the intake would just flip around, putting the trottle body at the rear and less in the way. I have just confirmed that it won't flip around. It's VERY close though. ports line up, holes line up, but those two horizontal sealing surfaces are different from front to back. I now have two options: 1. Modify those sealing surfaces 2. Mount the throttle body elsewhere on the manifold I'm leaning towards #1 because it looks easier. If I don't have room to mount the throttle body on the top of the manifold then that will force me to option #1.. which is why I need the measurement. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
bondo |
Feb 3 2005, 12:30 AM
Yup, sure did. You can find them here. Changing manifolds is way too much work. This manifold is pretty complicated. EGR and PCV are incorporated into it. I also really liked the way this engine performed in the Firebird before I pulled it. I don't want to mess with it too much. The distributor is on the front of the engine, so that won't be a problem. I think option #1 is the way to go. |
Lo-Fi Version | Time is now: 4th June 2024 - 05:57 AM |
