I NEED TO VENT!, (my crankcase) |
airsix |
Feb 3 2005, 01:52 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
I've been procrastinating away the winter, but it's time to address a few items before spring.
Oil leaks - Ok, this is my biggest problem and is the reason for this post. I'm getting a lot of crankcase pressure since I added the turbo. Off boost I've got no oil leaks. On-boost I've got leaks from the valve covers and pushrod tubes (both new and in good condition). I've got the rocker-box vents plumbed up to the spark-arestor where they are joined by the oil-filler vent hose and this three-into-one arangement then goes via single 5/8" hose to a home-made catch can. Do you think running these as three individual lines (rather than plumbing them down to a single 5/8" hose) would cure the problem, or do I need something more agressive in the way of venting/scavenging? -Ben M. |
Mark Henry |
Feb 3 2005, 06:56 AM
For the push rod tubes did you use the locktite pipe sealant with Teflon? Jake’s trick works real good. You can reuse your old seals as long as they are not cut. Clean every trace of oil before you reinstall them.
Where does your breather end up? Do you run a hose to the air cleaner, before the turbo? I do this on N/A’s but I don’t know if the oil mist would hurt a turbo. I’d ask over on the STF forced induction forum here |
Lo-Fi Version | Time is now: 8th June 2024 - 04:55 PM |
