> Longevity/reliability of a "sleeved" helicoil timesert spark plug hole
nditiz1
post Jan 21 2025, 06:08 PM
I recently acquired a 912e aka 2.0 Ljet. I was told it was running up until the point the 912e was disassembled. I find it very hard to believe when spark plug #4 hole does not thread a m14 spark plug. I will check an m16 bolt tomorrow when the hardware store opens as that is close to what I get with a micrometer. Now the hole is threaded. If I can get a m16 -> m14 reducer how well will it hold up? Should I only use a helicoil or even a timesert? OR if it does accept m16, get a studebaker m16 spark plug and gap accordingly?
Thanks all!
Montreal914
post Jan 21 2025, 07:56 PM
Knowing how the stock 2liter heads all crack here (picture) I would highly doubt with the reduced wall created by that insert your head wouldn't be cracked...
If once removed the heads are worthy of rebuild, I would seriously consider having them welded and drilled for 12mm plugs in hopes of avoiding future cracks.
- Lo-Fi Version Time is now: 15th June 2026 - 10:43 PM
