> Bypass Valve on Stock Oil Filter Console, Looking for relief pressure of bypass valve to help with design of remote oil filter and cooler
Mr Beckstar
post Jan 25 2025, 05:37 PM
Region Association: Australia and New Zealand
Hi all.
I have a 4 cylinder 2 litre and am adding a remote oil filter and oil cooler circuit via a spin on adaptor attached to the stock oil filter console mount. But I noticed the oil filter bypass valve in the stock oil filter mount (circled in photo below) and now I’m concerned that, at high rpm, I’ll be bypassing the remote cooler/filter circuit. Does anyone know the bypass valve relief pressure setting? Knowing that would at least allow me to judge whether it’s an issue.
Superhawk996
post Jan 28 2025, 10:15 AM
I don’t want to answer for OP but my understanding is he is worried about bypassing his external oil cooler and overheating. Operating oil pressure hasn’t been part of this conversation.
I view this discussion as largely theoretical. Unless the external oil cooler and plumbing is stupid restrictive the bypass in the oil filter console is a non issue.
On the other hand, if you do have a HIGHLY restrictive external cooler and hose assembly, the last thing in the world that you ought to be doing is plugging or increasing the relief pressure of the oil filter console bypass.
That situation of high external oil cooler restriction, is basically the same limitation of oil flow as a plugged & restricted oil filter. This can cause bearing damage due to loss of pressure and flow at the bearings. Which of course, is why the automotive engineers that designed the system put the oil console relief valve in there in the first place (ie to ensure oil gets to the bearings). This is why I initially suggested that the oiling diagram be looked at closely.
Mr Beckstar   Bypass Valve on Stock Oil Filter Console   Jan 25 2025, 05:37 PM
Montreal914   Good concern and already discussed here in the pas...   Jan 25 2025, 06:09 PM
Mr Beckstar   Good concern and already discussed here in the pa...   Jan 26 2025, 05:16 AM
Montreal914   Looks like it is a couple of psi. Read @[url=htt...   Jan 26 2025, 09:55 AM
Superhawk996   I hate chiming in on this because I don’t have a...   Jan 26 2025, 12:38 PM
technicalninja   :agree: I believe every single ICE engine with b...   Jan 26 2025, 01:00 PM
Mr Beckstar   Thanks for the great responses everyone :D If i...   Jan 27 2025, 07:11 AM
Superhawk996   Where in the world did you come up with 3 psi? I ...   Jan 27 2025, 07:44 AM
Mr Beckstar   Where in the world did you come up with 3 psi? M...   Jan 27 2025, 07:17 PM
Superhawk996   I’m also a mechanical engineer and done a fair...   Jan 27 2025, 08:15 PM
Mr Beckstar   I’m also a mechanical engineer and done a fai...   Jan 28 2025, 01:31 AM
Superhawk996   The spring will dictate the [force], the [area] i...   Jan 28 2025, 07:54 AM
Mr Beckstar   The spring will dictate the [force], the [area] ...   Jan 29 2025, 04:00 AM
emerygt350   And why on earth would you want to send cold oil t...   Jan 27 2025, 06:22 PM
Mr Beckstar   And why on earth would you want to send cold oil ...   Jan 27 2025, 07:22 PM
technicalninja   Where in the world did you come up with 3 psi? ...   Jan 27 2025, 08:19 PM
Mr Beckstar   Sadly, the old saying "if you want somethin...   Jan 28 2025, 01:35 AM
technicalninja   I’m also a mechanical engineer and done a fai...   Jan 27 2025, 08:25 PM
Mr Beckstar   [quote name='Superhawk996' post='3189070' date='J...   Jan 28 2025, 01:38 AM
GregAmy   Can I insert just a couple basic questions here? ...   Jan 28 2025, 08:11 AM
Mr Beckstar   Can I insert just a couple basic questions here? ...   Jan 29 2025, 04:16 AM
Superhawk996   I don’t want to answer for OP but my understandi...   Jan 28 2025, 10:15 AM
GregAmy   I don’t want to answer for OP but my understand...   Jan 28 2025, 10:23 AM
Superhawk996   I suggest it's a non-issue. But if you're...   Jan 28 2025, 10:27 AM
Mr Beckstar   I don’t want to answer for OP but my understan...   Jan 29 2025, 04:26 AM
Mr Beckstar   …I view this discussion as largely theoretica...   Mar 11 2025, 04:17 AM
Mr Beckstar   I looked at those two links and they’re not rele...   Jan 29 2025, 04:24 AM
Mr Beckstar   The oil filter bypass valve piqued my interest so ...   Feb 21 2025, 03:31 AM
Mr Beckstar   The above pressure readings were measured using th...   Feb 21 2025, 04:10 AM
Superhawk996   Interesting data points. Food for thought on the ...   Feb 21 2025, 08:40 AM
Mr Beckstar   Okay, I just used a brand new gauge with 0-15 PSI ...   Mar 11 2025, 03:13 AM
Mr Beckstar   Next step is to fit the two pressure tappings into...   Mar 11 2025, 03:29 AM
Superhawk996   You’re in uncharted territory as far as I know. ...   Mar 11 2025, 07:06 AM
Mr Beckstar   You’re in uncharted territory as far as I know....   Mar 12 2025, 02:29 AM
Superhawk996   Food for thought If you look at histograms of av...   Mar 12 2025, 07:55 AM
Mr Beckstar   Food for thought If you look at histograms of a...   Mar 13 2025, 01:49 AM
Superhawk996   At 68 MPH, the engine’s doing 4,200 rpm. Bei...   Mar 13 2025, 06:46 AM
- Lo-Fi Version Time is now: 9th September 2026 - 12:55 AM
